Author: Subject: Type 9 Clutch Release Bearing
rpsmith
posted on 18/6/07 at 07:21 AM Reply With Quote
How the hell do you get the clutch realese bearing off the type 9 box, i read the Haynes book of lies and it says to depress a couple of tabs at the back of bearing........ i tried this for about 2 hours with no success
Can anyone help please
mark-wiring
posted on 18/6/07 at 07:24 AM Reply With Quote
Just give it a good hard yank really its only a push fit onto the release arm
http://www.v10viento.co.uk
Have to recommend
http://www.extraefi.co.uk/
For all Megasquirt needs
rpsmith
posted on 18/6/07 at 07:25 AM Reply With Quote
Ahhhhh, i will try that tonight
Macbeast
posted on 18/6/07 at 08:07 AM Reply With Quote
I used a claw hammer - gently.
Have heard it said that the release bearing housing usually breaks as you take it off but no matter if yiou're going to replace it anyway
rusty
posted on 18/6/07 at 10:08 AM Reply With Quote
You could drive the pin out and get the arm off that way but you will have to deform the pin to make sure it stay in when you put it back.
snapper
posted on 18/6/07 at 10:46 AM Reply With Quote
There are two tiny metal spring tabs that open out a little when the bearing holder is pushed on to the arm, usually covered in oil and muck so hard to see.
Use a screw drive on the back of the arm pushing towards the bearing and you should easily be able to release one side of the bearing carrier, repeat for the other side and it will just slide off the input shaft.
In the past i have also knocked out the the pivot pin so i could slide the release arm and bearing of complete and take it in to the workshop.
just replace the pin afterwards with a little locktight and reassemble.
I eat to survive
I drink to forget
rpsmith
posted on 19/6/07 at 07:16 AM Reply With Quote
Cheers guys, claw hammer worked a treat, got it off in a matter of seconds
