rusty
| posted on 18/6/07 at 03:56 PM |
Long shaft Short shaft type 9 + 36mm Nut
Silly me I nid not even know there was a short and a long shaft type 9.
Have a broken short shaft and a repalment long shaft, decided to make one good one out of two and fit new bearings as I go.
Started stripping down and found 36mm ish 12 sided nut which i have no socket for. Off to the shops for me.
stevec
| posted on 18/6/07 at 04:00 PM |
I think you will find the short and long shafts have different ratios and are not interchangable.
Steve.
snapper
| posted on 18/6/07 at 04:03 PM |
If you put the long shaft in then your bell housing will need to be spaced out by 32mm or your clutch wont fit.
Just like putting the V6 box on a Pinto with the pinto bellhousing and if you are goint to do that then you would be better off putting a whole V6 box
in for the better ratios.
I eat to survive
I drink to forget
