Orange Indy
| posted on 19/6/07 at 08:53 PM |
Pinto Main Bearing Clearances
As part of my effort to find a reason for low oil pressure in my pinto engine I have tonight dropped the sump and checked the main bearing clearances.
The method I have used is to insert a piece of feeler gauge behind the shell then to re-tighten the cap and see if the crank is nipped. I found that
with a 0.05mm feeler in the crank would still turn, the crank would only nip with either 0.08mm or 0.1mm.
Assuming I have used the correct method this looks well over the recommended max in the Haynes manual of 0.063mm. Have I done this right and if so is
this the likely cause of my low oil pressure when the engine is hot?
The engine was only re-built last year and I am sure I checked the clearances just after the rebuild and they were okay, which coupled to the fact
that the oil pressure was a lot better then also makes me think this is the problem.
Any help would be really appreciated.
mookaloid
| posted on 19/6/07 at 08:57 PM |
I would have the crank measured at an engineering shop and then order a new set of shells to match.
Can't be the problem after that.
HTH
Mark
jacko
| posted on 19/6/07 at 08:58 PM |
What do you call low pressure ?
Orange Indy
| posted on 19/6/07 at 09:06 PM |
When it is properly hot, down to about 15psi. 75psi when cold using 20/50.
DRC INDY 7
| posted on 19/6/07 at 09:13 PM |
is the low pressure when its hot on idle or hot with 2500/3000RPM
Puddle Dodgers Club
jacko
Is that on tick over or reving in ie 3000 rpm
Orange Indy
| posted on 19/6/07 at 09:20 PM |
Even under revs once the oil gets properly hot (unfortunately I cannot say what 'hot' is as I have not oil temp gauge) after the engine
has been running for 30mins or so, the pressure drops off. Does not drop below 15psi though even on idle.
jacko
| posted on 19/6/07 at 09:26 PM |
My engine had a full rebuild last year when hot at tick over it has 15 psi at driving speed about 3000 rpm it has about 50--60psi i dont see a
problem with this
Jacko
andyharding
| posted on 19/6/07 at 10:19 PM |
I had my Pinto built with 2x the normal clearance for maximum power and have a high pressure high capacity oil pump. Running fully synth oil.
When hot I get about 15psi at idle going up to about 50-60 at few 1000 revs. When cold it's off the gauge at 90psi.
Orange Indy
| posted on 20/6/07 at 09:11 PM |
Bearing Clearances
So has anyone go any views on my clearances? Have I used the right method to check them and is the fact that they are this much over the recommended
gaps the probable cause of my low oil pressure when the oil is hot?
James
flak monkey
| posted on 20/6/07 at 09:23 PM |
Your main bearing clearance should be 0.05-0.064mm. Toward the higher end if possible for a high performance engine.
The only proper way to measure bearing clearances is with Plastigauge, as even measuring with a micrometer with the crank out will give you variable
results due to how the bearings are made and how they fit in the tunnels.
Sera
http://www.motosera.com
| posted on 20/6/07 at 09:32 PM |
You can get Plastigauge from Burtons - fairly cheap, and comes with instructions. If you do what's required then you'll know exactly what
the clearances are.
Orange Indy
| posted on 21/6/07 at 10:09 PM |
Thanks - will give that a go.
