Author: Subject: Tiptronic gearboxes?
RazMan
posted on 20/6/07 at 09:09 AM Reply With Quote
Has anyone used one of these in a kit car? How did you overcome the ecu control issues?
Just thinking of a possible future project
Raz
JamJah
posted on 20/6/07 at 09:20 AM Reply With Quote
Depends which Tipronic box your using / what clutch system it has. If its from the smart roadster id say forget it. Hence the AC using a new manual box!!
Volvo use a good tipronic, as does BMW. As the police round here both use them with tipronic boxes they must be fairly smooth too.
This is personal advise or personal opinion.
Constructive comments gratefully recieved, picking is left for noses.
RazMan
posted on 20/6/07 at 09:33 AM Reply With Quote
I know there are quite a few tiptronic type boxes used on tintops - I just need to know if torque converter settings can be adjusted to compensate for the sudden loss in weight when used in a lighter car. Also modern security and emissions systems often make it very difficult to use the original ecu and all of the aftermarket ecu's that I know of would not be able to control the gearbox.
[Edited on 20-6-07 by RazMan]
Raz
Ivan
posted on 20/6/07 at 10:33 AM Reply With Quote
I would love Tiptronic boxes in my two kit cars.
Kind of like having a sequential box without the cost or having to put up with the limitations of a bike engine .
As you say sorting out the programming is the problem - I think the manufacturers of aftermarket ECU's would be best able to answer whether this is possible.
Also - not even the big car manufacturers can get it right every time so what's the chance that the likes of you and me will get it right.
