rpsmith
| posted on 22/6/07 at 12:36 PM |
Pinto Cam Pulley Removal
Is there anything i should know about removing the cam pulleys on a pinto EFi engine, i am borrowing a gear puller from work over the weekend, so i
don't want to get stuck half way through the job
Is it worth putting some WD40 on all the gears tonight to let the soak in?
westf27
| posted on 22/6/07 at 12:41 PM |
mine didnt need a puller,came straight off
ash_hammond
| posted on 22/6/07 at 12:55 PM |
same here
.: www.mac1motorsports.co.uk | www.m1moc.com :.
caber
| posted on 22/6/07 at 01:07 PM |
Should come off OK it is located by a Woodruff key so watch out and don't lose it!
Caber
| posted on 22/6/07 at 01:18 PM |
Mine came off with a light tap from behind using a block of wood - certainly didn't need a puller. It's not an interference fit, so it
should be easy to remove. As mentioned don't lose and of the bits.
rpsmith
| posted on 22/6/07 at 01:26 PM |
Nice one, cheers guys
jollygreengiant
| posted on 22/6/07 at 02:13 PM |
The ONLY pulley on a pinto that is EVER tight is the bottom pulley on a pinto Injection. For that one only, you will need a puller. (easily identified
because it has a double V for twin drive belts.)
