phil m
| posted on 1/7/07 at 04:05 PM |
camshaft timing
I 've just been installing my new camshaft (kent bcf2) into the crossflow and have timed it - hopefully correctly- (108 degrees at full inlet
lift)
Does anybody know the timing figure for an origional 1600gt camshaft. Just out of interest really - no other reason!
Thanks, Phil
Confused but excited.
| posted on 1/7/07 at 05:49 PM |
A 1600 inlet valve opens 27deg BTDC, closes 65deg ABDC.
So I make the figure 109deg ATDC if I have worked it out correctly.
[Edited on 1/7/07 by Confused but excited.]
phil m
| posted on 1/7/07 at 06:15 PM |
Thanks for the answer - how do you arrive at it using the inlet/exhaust figures ?
Interested as the old timing marks on the cam sprocket and cranskshaft are pretty close with the new cam - a bit of a sanity check
