Ratters
| posted on 5/7/07 at 05:36 PM |
Bike Fuel Pumps
If using Kawazaki ZX9R carbs on a x-flow I have heard the standard pump can be used. Is this true??
What's the best bike fuel pump to use?? Can any one be used as long as it's for a carb bike not tb's?? Are any better than others
with built in regulators or anything like that??
bigrich
| posted on 5/7/07 at 05:45 PM |
for no other reason than it works with the carbs you have use a kawasaki one for zx9r, but i would say any "carbed" fuel pump, R1,Blade
etc would be ok.
thesnake505
| posted on 5/7/07 at 06:29 PM |
the other option is a fuel regultor, i run standard pinto fuel pump and a fuel regultaor set at 2psi and it runs fine,
regulator from demon tweeks, can be found here link
hope this helps
ChrisGamlin
| posted on 5/7/07 at 09:22 PM |
a solid state pump and regulator have proven troublesome on some BECs, strangling flowrate at pressures low enough so the pressure doesn't
overcome the needles, so Id personally steer clear although they do undoubtedly work OK for some.
From what Ive seen most large bike engines with carbs that have a pump use pretty much the same Mitsubishi sourced pump, as mentioned above something
from an early blade or an R1 will be fine.
Chris
thesnake505
| posted on 5/7/07 at 10:03 PM |
im not sure if iv missunder stood something, is he not running a set of bike carbs with a ford xflow engine???
ChrisGamlin
| posted on 6/7/07 at 08:51 AM |
Yep, but its the carbs that are important regardless of what engine they are strapped to. Bike carbs need a bike carb friendly fuel pump configuration
Ratters
| posted on 8/7/07 at 06:01 PM |
Thanks for the replies.
I have found a motorbike breakers through the good old tinternet not far from me & they have ZX9R pumps there for £20 plus postage if I
can't be bothered to go get them
Just a simple case of a switch & a relay then
