Author: Subject: ford 4.6 v8 NEW
bj928
posted on 8/7/07 at 03:47 PM Reply With Quote
ford 4.6 v8 NEW
can i have some comments please, what would this engine be worth, its brand new, all alloy heads and block, rated at 375bhp and 365Ib/ft, it revs to 7000rpm, has 32v quad cam heads, has carbs and the ignition is included, also flywheel for manual or auto, basicly stick it in the engine bay, add a couple of wires and some fuel and fire it up. clutch and gearbox would be standard mustang 5 or 6 speed or auto
thinking of shipping a few in but want some feedback first.
bilbo
posted on 8/7/07 at 03:55 PM Reply With Quote
There is a firm who import similar engine packages:
http://www.ekmpowershop.com/ekmps/shops/powertorqueen/index.asp?function=DISPLAYCAT&catid=8
Might give you a feeling for price.
Of course, you can always sell me one for £10
Build Diary: http://bills-locost.blogspot.com/
Web Site: http://locost.atspace.com
bj928
posted on 8/7/07 at 04:12 PM Reply With Quote
most those v8's need inlet or at least carb and are cast iron block and low revving, and they are less HP, and all need ignition, the only one that is all alloy and 25hp more is almost £12000!!!!!.
british american engines are even dearer.
bilbo
posted on 8/7/07 at 04:19 PM Reply With Quote
You could well be on to a winner then if you can seriously undercut the opposition
mark-wiring
posted on 8/7/07 at 04:31 PM Reply With Quote
Well put it this way £12000 is far too much i know how much John has in mind and its fair to say it will surprise you when you consider the alternatives.
What John is after is what people really think this engine package is worth and if any one is really that interested they will actually want one
http://www.v10viento.co.uk
Have to recommend
http://www.extraefi.co.uk/
For all Megasquirt needs
Deckman001
posted on 8/7/07 at 04:50 PM Reply With Quote
I would have thought a Cobra forum would be a better bet ??
Jason
Syd Bridge
posted on 8/7/07 at 04:54 PM Reply With Quote
You would need injection and an ecu to get one of those on the road. Remember, they're new engines and need cats.
In the USA, a quad cam with all the ancillaries, including the full injection system, can be had NEW for less than $9kusd. And in some cases much less. My mate in Minneapolis has had them for less than half the above price, direct from the ford assembly line, and then the QA checking section.
Also, those carb engines are probably marine engines with car exhaust manifolds. They'll also have slightly hotter cams. The marine items can be bought in pairs, in Florida, for less than $10k. Just got to shop around.
Syd.
[Edited on 8/7/07 by Syd Bridge]
Bob C
posted on 8/7/07 at 05:59 PM Reply With Quote
you could build up a 4.6 rover V8, all new, for about 3 grand - but it would be 100 horse down on that; It would be considerably smaller (no dual overhead cams on each bank) and probably quite a bit lighter ????
That does look like an interesting package but as said above, the carb would be slung for a street kit
Bob
mark-wiring
posted on 8/7/07 at 06:48 PM Reply With Quote
Syd.
Engine comes complete with ecu and its carb so dont need injection.
All you need to add to this is engine mounts clutch and gearbox exhausts cats wont be required if the car is a Q plate or even if it has an age related plate thats before cats were required.
Its not a marine engine.
Have to recommend
mark-wiring
posted on 8/7/07 at 06:53 PM Reply With Quote
Bob
Whats wrong with a carb engine?
Have to recommend
bilbo
posted on 8/7/07 at 07:03 PM Reply With Quote
Nothing, except as it's a new engine, it will have to go through the latest emission tests at SVA, which a carb will not be able to pass.
mark-wiring
posted on 8/7/07 at 07:06 PM Reply With Quote
Ahh that could be true.
Upgrade engine tho would be perfect idea?
Have to recommend
Simon
posted on 8/7/07 at 07:13 PM Reply With Quote
bg/mark,
Don't want to dampen anyones enthusiasm, but I have the 16 valve version of that engine in my ZT260, and compared to the R V8, it's massive.
Now, the Chevy LS1 (which produces around 400bhp) is about the same size and weight as the R V8, so may be a better bet. Get me (a complete/low mileage) one of those with 5 speed box, and I'll happily find a grand for you
Simon
[Edited on 8/7/07 by Simon]
NS Dev
posted on 8/7/07 at 07:31 PM Reply With Quote
No idea on the lower spec engines, but I know that my mate at ultima pays around £11,000 for a 700hp, 600lbft torque 377ci chevy smallblock running on a carb, with all steel bottom end, etc etc, so £12k for half the power is not cheap! (ps this is an aftermarket alloy head and alloy block engine, no cast iron stuff!
I think you are looking at around £5k to £5.5k for a brand new 350ci, 350hp LS1 chevy these days, and around £3k for the same power from a "new" smallblock
[Edited on 8/7/07 by NS Dev]
rickys2000
posted on 8/7/07 at 07:52 PM Reply With Quote
BJ/Mark
Its a good idea to bring competition and more choice to the market, but, what do you intend to do or plan to do for aftersales, warranty, spares etc. if you sell any units
thx
Ricky
Syd Bridge
posted on 9/7/07 at 09:06 AM Reply With Quote
How does the ecu control the carb mixture? At best, it's for ignition only.
Take the car exhaust manifolds off, and that engine in the pics looks EXACTLY like a bare, crate, marine engine.
If it comes with a carb as standard, it's not produced for road use. Ask your friendly SVO or Ford marine agent. Although, the yanks seem to get away with them in street rods.
Syd.
