oadamo
| posted on 8/7/07 at 05:10 PM |
got me some scales
put my diff on its a sierra 4x4 didnt think it was that much.
[Edited on 8/7/07 by oadamo]
| posted on 8/7/07 at 05:12 PM |
yup, 20odd open and that ^^^ with LSD.
ouch!
[Edited on 8/7/07 by JoelP]
oadamo
| posted on 8/7/07 at 05:27 PM |
could i use this to do corner weights by any chance or would i need 4.ive found 2 uses so far ive done my diff and myself pmsl
adam
ChrisGamlin
| posted on 8/7/07 at 07:48 PM |
Firstly it depends how high they go, you'll need at least 130-140kgs per corner for a BEC (inc driver), and more for a car engine'd
variant.
Doing it with only two scales is never going to be that accurate because you'll need to put blocks under the two remaining wheels and will need
to jack the car up between readings which will upset the accuracy quite a bit as the suspension settles / unsettles.
