will121
| posted on 9/7/07 at 07:34 AM |
lack of oil pressure!
i brought a recon 1600 cvh engine, finally got it fitted but turned it over but cant get any oil pressure! think it may be the builder never primed
the oil pump. is there a way of priming it through the oil filter or pressure switch or is it just a case of keep turning the engine over and hope for
the best? thanks
Danozeman
| posted on 9/7/07 at 09:07 AM |
Is it definatley no pressure not just the switch knackered?
Dan
Fozzie
| posted on 9/7/07 at 09:31 AM |
will 121,
I have moved your post to the appropriate section.......
Fozzie
will121
| posted on 9/7/07 at 11:34 AM |
thank you,
muzchap
| posted on 9/7/07 at 12:16 PM |
I dont think he wants to sell - more swap his low oil pressure for good oil pressure
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
will121
| posted on 10/7/07 at 03:26 PM |
just to keep up to date, in the end i connected up the bike carbs, quick spray of easy start and it started after 3 years instantly and oil pressure
straight up to 45psi!!!
