robertst
posted on 10/7/07 at 04:10 PM |
crankshaft sprocket
how can i remove it? the puller doesnt fit...
do i have to remove the crankshaft itself to remove the sprocket?
the haynes manual doesnt say anything, it just says "remove the sprocket"....
cheers
Tom
jollygreengiant
| posted on 10/7/07 at 04:35 PM |
The front pulley (alternator drive) will need a pulley if an injection engine. Once this is removed then the cambelt drive cog does come off but
usually needs a little persuasion with some wedges from behind/the side ( a very thin flat chisel or a medium screw driver.).
Hope this helps.
