Jimbob
posted on 13/7/07 at 03:40 PM |
chopping zx9 oil pickup
Hey guys, anyone know a tried and tested method? want to shorten the standard part but not sure of the best way to 'glue' it back together
after chopping the straight part out?
ChrisGamlin
| posted on 13/7/07 at 04:52 PM |
If you want both the pickup and the sump itself chopped, my uncle does them in his spare time when he's not welding / prepping various race cars
for £60 + postage.
If I knew exactly how he chopped the pickup I would gladly share it but Im not sure, I know there's a bit of a lip on some of the plastic ones
somewhere which he uses to pretty much make a snap-shut fitting between the two bits once chopped, although obviously its glued as well. He must have
done maybe 20-30 of them by now and not had a problem as far as Im aware.
  Chopped XR9R sump 1
  Chopped XR9R sump 2
Chris
[Edited on 13/7/07 by ChrisGamlin]
Wadders
| posted on 13/7/07 at 05:23 PM |
I arldited my first one and it worked fine, there are 3 raised lugs in the sump bottom that sit tight under the pickup so it can't fall off even
if the glue fails. i welded 3 bits of 8mm ally round bar in the bottom to replicate the lugs.
Al.
Jimbob
| posted on 13/7/07 at 05:25 PM |
Cheers chris, very neat job and great offer but i can do the welding myself. Was mainly worried about what glue to use and if it will fail due to heat
etc...
better not mess with it till after sva on the 26th tho!
cheers james
Jimbob
| posted on 13/7/07 at 05:28 PM |
araldite it is then!
cheers Al
James
ChrisGamlin
| posted on 13/7/07 at 05:38 PM |
No probs, I'll try and find out what he uses to glue them and let you know.
