thesnake505
| posted on 13/7/07 at 08:03 PM |
mega jolt question
hay all im running a 1.6 pinto on bike carbs, and im wondering what mj to get, the tps or the map virsion? now i have the ablity to run vacum and im
under the impression this is the best way to use mj, however to run a vacum i need a plenum type thing as on the website
has any one else gone down this route with the vacum plenum if so how big did u make it etc......... cheer the snake
http://www.autosportlabs.net/index.php?title=Choosing_between_MAP_or_TPS
[Edited on 13/7/07 by thesnake505]
big_wasa
| posted on 13/7/07 at 08:10 PM |
tps for multi carbs and map for a single carb
snapper
| posted on 14/7/07 at 07:37 AM |
I have MAP on my Mikunies, they have individual vacuum take offs which go to a small 10mm tube plenumn, this smooths out the pulsing and lets the MAP
sensor see a constant vacuum
I eat to survive
I drink to forget
TangoMan
| posted on 14/7/07 at 02:20 PM |
MAP is generally better, but only if you have a good and stable manifold vacuum.
With independent TB's or carbs the MAP can easily reach 100KPa while only or part throttle and may not to too stable at low RPM. Especially with
a performance cam.
I ran TPS on my Megajolt and was very happy with it. I run MAP on my Megasquirt though as it is better for measuring the fueling requirements.
I think he simple answer is both will do the job but the best depends on your setup. Both will be significantly better than the old 2D dizzy.
Summer's here!!!!
