Martian
| posted on 19/7/07 at 12:55 PM |
crossflow sorted!
took carb off car and stripped all jets, etc and found a load of crystals below the emulsion tube (which didn't want to come out) on the primary
barrel. this crud was blocking that main jet also. i hadn't noticed it before because of artificial light in shed. i only noticed when i took
it outside into sunlight! after a good soak in carb cleaner and blowning out with airline, i rebuilt carb, refitted it, and , hey presto!, she runs
perfectly! i have discovered a small hiccup in as much that the speedo reads 40mph when the car is doing 60mph! (i'm using mini speedo, escort
4speed box, sierra lsd, 14in wheels!) today, put brake fluid in, bled brakes and drove it up garden track and back. MINT!
| posted on 19/7/07 at 01:02 PM |
You did 60mph in your garden
Martian
| posted on 19/7/07 at 01:07 PM |
 no it was on axel stands! i'd worked out that at 3000revs in top gear, it will be doing 60mph
speedyxjs
| posted on 19/7/07 at 02:33 PM |
Would have been funny if your axle stands gave way Great way to anoy the neigbours when their fence collapses
| posted on 19/7/07 at 05:48 PM |
Speedy Cables can recalibrate the speedo for you for not an awful lot of money.
