Author: Subject: Zetec to T9 (the holes)
Jonte
posted on 20/7/07 at 12:32 PM Reply With Quote
Yeah I know it´s been asked before to fit a zetec to T9.
But I can´t find answers how to do with the big holes (gaps) that is on the sides when the two of them are together. I don´t want all sorts of dirt and stuff in to the clutch.
If you have a solution, please attach a pic if you have it.
Tried searching but came up with nothing
Click it
Hammerhead
posted on 20/7/07 at 12:45 PM Reply With Quote
I think you need to search for a blanking plate.
Some people sandwich a thin (1 or 2mm) piece of aluminium sheet cut to shape between the engine and bellhousing. This will blank the gaps and stop anything getting into the cluth assembly.
Steve.
r1_pete
posted on 20/7/07 at 02:03 PM Reply With Quote
Use the type 9 plate and weld bits in, thats what I've done with an MT75 to P3 Zetec.
What starter are you using? I'm having real problems getting one to fit?
UncleFista
posted on 20/7/07 at 02:37 PM Reply With Quote
I'll second the "weld the original" plan, I made one from scratch from 1mm steel sheet. Was a PITA...
Tony Bond / UncleFista
big_wasa
posted on 20/7/07 at 03:26 PM Reply With Quote
pic
TangoMan
posted on 20/7/07 at 06:44 PM Reply With Quote
I used the Pinto back plate with a piece welded in where the Zetec starter usually goes.
For a starter you need one off a 1.8 CVH Sierra or a DOHC.
I got mine new off ebay fr a reasonable fee.
Summer's here!!!!
stevebubs
posted on 20/7/07 at 10:13 PM Reply With Quote
Yep - I've a 1.8 CVH Sierra Starter on mine - from a G plate car, if that helps.
Jonte
posted on 21/7/07 at 11:11 AM Reply With Quote
well not me, have no clue what G plate car is
But for a starter I´ll be using a sierra cvh as already mentioned here.
It´s a 2.0l silvertop zetec
Click it
