| posted on 29/8/03 at 11:13 AM |
Engine mount rubber
What is a suitable rubber to use in the engine mounts? Can't plan them till i work out what to use...!
ta all...
Steve Hnz
| posted on 29/8/03 at 12:02 PM |
I`ve seen recommended Land Rover Series III type engine mount rubbers & from my experience of same in a Land Rover they`re what I intend to use
when I get to that stage. ( Still Planning.)
Mark Allanson
| posted on 29/8/03 at 01:20 PM |
Part Number NTC5890, £5.60+VAT
| posted on 29/8/03 at 01:49 PM |
Cheers ste and mark.
On that one mark is it one bolt all the way thru, or two bolts?
Also is that one the land rover one? and would most motor factors stock them?
James
| posted on 29/8/03 at 02:20 PM |
Fiesta Gearbox mounts are seem pretty good too- it's what MK use.
HTH,
James
Mark Allanson
| posted on 29/8/03 at 02:32 PM |
Joel, It has separate studs from both sides, they are really stuff and hold the engine firmly, they are genuine Landrover - couldn't tell you
which one - I just went into the back stores and picked up what looked the most suitable!
| posted on 29/8/03 at 05:50 PM |
Ah well, i've ended up with fiesta engine mounts, they look like they'll do the trick! Couldn't find anywhere that stocked the other
bits.
Conviniently they're 1.5 inches thinner than the original sierra ones, and thats exactly how much i wanted the engine down by! Might just
replace the rubber and leave the rest the same!
