mad dad
| posted on 21/7/07 at 05:37 PM |
What petrol do you use in bec's
As above never sure whether to use Shell V Power or BP equivalent or just run on normal 95 octane?? does it make any difference to performance on a
bec......i know it use to in my Subaru but would be interested to hear what people use....Cheers Andy
bigrich
| posted on 21/7/07 at 05:47 PM |
the standard 95 octane is more than enough for a standard bike engine.
if its been tuned,compression increased etc then the super stuff may benifit it
all IMHO of course
mad dad
| posted on 21/7/07 at 05:49 PM |
its dyno jetted but thats all thats been done......
Jon Ison
| posted on 21/7/07 at 06:02 PM |
all IMHO of course
What he said, anything else is a waste of money.
| posted on 21/7/07 at 06:05 PM |
What they ^^^^^^ said.
Phil
mad dad
| posted on 21/7/07 at 06:07 PM |
that seems sorted then i'll go with what they said above
DIY Si
| posted on 21/7/07 at 06:24 PM |
According to Haynes, my bird is specced for a minimum of 91 RON fuel!
Sun Tzu, The Art of War
| posted on 21/7/07 at 10:43 PM |
I use cheap and nasty RON95... When I fit the 'charger however, I may have to upgrade to RON98!!!!
graememk
| posted on 21/7/07 at 11:38 PM |
i cant tell the differance
tks
| posted on 22/7/07 at 05:16 PM |
offcourse you can tell the difference but only in your pocket...
tks
ChrisGamlin
| posted on 24/7/07 at 12:57 PM |
I generally use V Power / BP Ultimate etc in my injected R1 on track but only because I've got a PC3r Power Commander which adjusts fuel and
ignition, and the map Im currently running is from a similar race car setup which I assume was probably set up for 98 RON.
Unless you adjust the ignition advance on a rolling road to suit the fuel (not possible on a standard blade engine without an ignition advance gismo
or you convert to throttle bodies and mappable ignition), or your ECU is self adapting to suit the fuel being used (which hardly any if any bike
engines do) then there's no performance benefit, although there may be a cleaning benefit as the premium fuels tend to have better cleaning
additives in them, especially when compared to supermarket fuel.
chockymonster
| posted on 24/7/07 at 03:22 PM |
If it's the map you gave me then it has the standard PC3R R1 engine timing, advance has not been adjusted at all.
ChrisGamlin
| posted on 24/7/07 at 06:09 PM |
It probably is! I must admit Ive not looked at the map Im using since I put the R1 in as the laptop I used originally is now dead and Ive not needed
to change anything since so havent installed the Power Commander app on my new laptop. I thought both ignition and fuel had been altered seeing as it
was generated on a rolling road originally, but maybe Im imagining things. Still, thats good news in a way as there should be some minor improvements
if I ever get round to setting it all up properly on a RR!
DIY Si
| posted on 24/7/07 at 06:25 PM |
Do many bikes have knock sensors? Mine does, but quite as to how much the engine uses it, I don't know.
ChrisGamlin
| posted on 24/7/07 at 07:29 PM |
Not many I dont think, certainly none that I know of. Maybe its trickier to detect at the higher rpm of a bike engine?
