Author: Subject: My starter motor fell off!
samwilliams
Junior Builder
Posts 86
Registered 21/7/04
Member Is Offline
Photo Archive Go!
Building: Bought (yeah, I know it's cheating) Sylva Pho
posted on 23/7/07 at 12:22 PM Reply With Quote
My sylva phoenix has been very uncooperative of late and, just to add to the fun, the starter motor fell off yesterday. I guess some of the bolts must have come out before, but I tried to start the car, it didn't work, had a look, and it was sitting there hanging out! I managed to get it started in order to get home by using one bolt I managed to find (possibly foolish, but it's done now), which didn't sound very healthy, but got it started. This fell out on the way home as well.
I've got a couple of questions hopefully you may be able to help me with. It appears that two of the bolts thread into the bellhousing, while the other one goes straight through to a nut. Does this sound right, and what thread do the two need? Also, could it be possible that I've buggered up my flywheel? I've got a spare starter motor, so I can try that as well. If neither work, is that likely?
Sorry if either of those questions are stupid!
Sam
Humbug
posted on 23/7/07 at 12:25 PM Reply With Quote
Depends on the exact setup, I guess. I have a 3-bolt starter fixed using only 2 bolts becase the third one is inaccessible (Type 9 to Rover K series bellhousing). I just used threadlock and have had no problems, touch wood!
nitram38
posted on 23/7/07 at 12:27 PM Reply With Quote
If the threads are ok, I would use loctite and a spring washer on your bolts.
If the threads are sh*gged but have no cracks, then the best option is helicoils.
This is best left to someone who knows what they are doing, plus they will need some room to work, so you might have to take a few bits off!
jamesbond007ltk
posted on 23/7/07 at 12:51 PM Reply With Quote
I had this happen on my Pinto+type 9. Starter fell off whilst driving along, at night. First thing i noticed was lights dimming and then sparks from under car! Then burning wire smell!
Turned out terminal on rear of starter had shorted onto chassis (it is now insulated to a far higher standard than before). Burning wire was chassis earth strap.
Think I got off pretty lightly to be honest! Lesson learnt regarding dodgy insulation of starter terminal.
Anyway, point is starter is now held on with three bolts as normal but with loctite. Many hard miles later and no further problems.
Rich
samwilliams
Junior Builder
Posts 86
Registered 21/7/04
Member Is Offline
Photo Archive Go!
posted on 23/7/07 at 12:58 PM Reply With Quote
thanks for the replies. Any suggestion on exactly what bolts I'll need?
Also, in terms of whether I've done any other damage at all, is there any easy way to check, or is it simply a case of fixing the starter motor and then seeing if it still doesn't work?!
(it was driving along fine after I managed to get it started using one bolt)
[Edited on 23/7/07 by samwilliams]
samwilliams
Junior Builder
Posts 86
Registered 21/7/04
Member Is Offline
Photo Archive Go!
posted on 23/7/07 at 02:27 PM Reply With Quote
I've managed to get the starter motor on securely (not with a permanent solution, but enough to check if it's still working at all).
Sadly, it does not.
While it was off, I took a picture inside which seems to me to be ok (now in my photo bit). However, the starter motor basically makes a grinding noise when the ignition is turned. Any ideas?!
cadebytiger
posted on 23/7/07 at 03:46 PM Reply With Quote
do you have any unusual vibrations?
The reason i ask is that my start fell off (pinto/type9) and it was caused by a rotational vibration coming from the prop shaft which turned out to be too short!
The central UJ what doing sillybuggers and would make noise at about 70ish.
samwilliams
Junior Builder
Posts 86
Registered 21/7/04
Member Is Offline
Photo Archive Go!
posted on 23/7/07 at 04:02 PM Reply With Quote
No, other than this, everything seems to be fine. Can't quite work out whats wrong at the moment, as from the picture the flywheel looked ok (I think - not 100% sure, but it looked ok to me), yet even then with a new starter motor on pretty much properly, it makes a nasty noise that it never made before and won't turn the engine.
I'm a little stuck!
posted on 23/7/07 at 04:43 PM Reply With Quote
Turn the engine over with a spanner on the crank pulley nut and try it in another spot if the pinion is alright on your starter.
samwilliams
Junior Builder
Posts 86
Registered 21/7/04
Member Is Offline
Photo Archive Go!
posted on 23/7/07 at 05:25 PM Reply With Quote
I've just tried that, but no difference. It turns the engine over a tiny bit sometimes, but not properly.
Would there be any benefit to taking the starter motor off in order to look at the flywheel while turning the engine completely, to check that it looks ok the whole way round?
posted on 23/7/07 at 05:48 PM Reply With Quote
Would be a good idea to check all the teeth on the flywheel . Seem to remember starters coming loose on x flow engines was fairly common , if that is what you are using. Count the number of teeth on the pinion as well
posted on 23/7/07 at 07:52 PM Reply With Quote
Bet you haven't got the shim plate fitted between the engine and bellhousing.
samwilliams
Junior Builder
Posts 86
Registered 21/7/04
Member Is Offline
Photo Archive Go!
posted on 23/7/07 at 08:06 PM Reply With Quote
Should there be one with a crossflow? If so, you might well be right, as it could have fallen off completely when the starter motor did.
posted on 23/7/07 at 08:31 PM Reply With Quote
Hadn't realised it was a crossflow...
Rattling around under the car might have damaged the pinion and/or the spiral it runs upon. Check that you can spin the pinion back towards the motor by hand - it's on a spiral thread, so as you twist it should go back. If the pinion's stuck, all you'll get is a loud electric motor whirr and the engine won't be spun over.
I know you've tried a spare starter - but this was such a common problem with inertia starters, your spare might also have a stuck pinion! They only work if they're in reasonably good condition, and it doesn't take much to confuse them (been there, done that).
A quick way to check is to get the starter out and try it on the bench - clamp it TIGHT using a workmate, clamps, or whatever, as these starters can recoil with some force. Then connect up jump leads (batt negative clipped to casing, positive touched to the connector) and give it a spin. If all is well it should spin vigorously, and the pinion should be seen to turn, and fly back towards the casing. Don't overdo this testing, as it's hard on the battery, jump leads and the starter!
If you do this test then at least you'll have eliminated it from your investigations.
If all is well, then it's time to look at the ring gear on the flywheel...
As for the shim plate - it won't fall off unless the engine is completely unbolted from the bellhousing - it's a cover that stops muck flying up from the road. If you reach under the car, you'll see where the bottom of the bellhousing meets the back of the engine - if you've got the shim you'll see that there's a sheet metal cover over the gap. If you can get your fingers in, there's no shim. I doubt if this is significant at the moment, as it used to work for you. It's best to have the shim, but it will sort-of work without it.
HTH,
[Edited on 23/7/07 by David Jenkins]
samwilliams
Junior Builder
Posts 86
Registered 21/7/04
Member Is Offline
Photo Archive Go!
posted on 23/7/07 at 09:15 PM Reply With Quote
Both starter motors seemed to be ok (well, the pinion wasn't stuck). The engine certainly hasn't come away - other than starting, the car seemed to be running fine.
Will have a look at the flywheel tomorrow.
posted on 24/7/07 at 08:03 AM Reply With Quote
OK - not the starter itself.
Had another wild thought... are you absolutely sure that the electrical connections are still intact?
That the starter itself has a really clean connection to the block/gearbox?
That the starter lead is 100% intact, and has a good and tight connection?
If the connections aren't as good as they should be, you can get enough current for the starter to attempt to kick the engine over, but not enough to do it properly. That would make an unpleasant noise!
As I said, this is just a case of considering all options, before you have to pull the engine & gearbox out...
HTH,
posted on 24/7/07 at 01:06 PM Reply With Quote
The shim plate locates the starter accurately Xflo MUST have the shim plate or you get all sorts of trouble -- jammed starters, chewed Bendix pinions, starters falling off.
samwilliams
Junior Builder
Posts 86
Registered 21/7/04
Member Is Offline
Photo Archive Go!
posted on 24/7/07 at 03:32 PM Reply With Quote
Been looking some more. Checked the flywheel the whole way round, and it all looks the same, which appears to be fine to me. There is, I believe, a shim plate on already (I didn't really know what it is, but there's certainly a thin sheet of metal there which i presume is it). I'm fairly sure that the connections are good, but will clean them up to make sure.
However, I still haven't got perfect bolts for the job. Got a couple which I thought were good enough just to get it started to get somewhere to get better ones, but maybe not. The problem is that I don't know what size and thread I need. Can anyone help me with that?
Unfortunately I don't have a load to try out to work it out, and can't get the car started in order to get it somewhere that might! At least then I'll be able to completely eliminate that, and be able to go back to having no idea whatsoever!
posted on 24/7/07 at 05:00 PM Reply With Quote
What gearbox/bellhousing do you have ? it may make a difference to what bolts you need.
samwilliams
Junior Builder
Posts 86
Registered 21/7/04
Member Is Offline
Photo Archive Go!
posted on 24/7/07 at 05:28 PM Reply With Quote
It's fixed! At this point, I should shut up and walk back to my corner, as the solution is fairly embarassing.
Managed to get hold of the right bolts (someone suggested taking one of the ones attaching the engine to the bellhousing, and getting some that matched up - that worked). Previously, when I'd been attaching it, I'd only been bothering with two of the bolts, because the third was very awkward to get to and I figured that it wouldn't make a significant difference in the short term. Well, as I now had bolts that fitted properly, I decided to do all three. As i got to the awkward one, i got a little confused. It didn't seem to line up quite right.
Oops!
It turns out that starter motors don't work very effectively when they're not the right way round! I suppose that the whole time I'd been trying to attach it 90 degrees out which, while attaching nice and snugly from the two bolts i was using, was, quite frankly, wrong.
It is now working.
Thanks for all your help, and I'll try and be a little less stupid next time!!
