Author: Subject: New gearbox
Pants On Fire
posted on 23/7/07 at 02:25 PM Reply With Quote
New gearbox
My gearbox needs to be replaced, probably got a few hundred left in it so a trip to the Ring at the end of August will mark its demise I'm sure. Trailering there & back so not worried about getting there & back!
The last box (a so called pro competition box) lasted 3500 miles with 240 Bhp and 175 ft/lbs of torque and a red line of 7800 rpm so whatever I go for needs to handle this power and to last beyond 3500 miles.
I'm thinking of a 2.8 T9 from BGH Geartech with a 2.83 1st and a 0.87 5th gear, their E6 Road & Track heavy duty product with a short input shaft for the XE & SBD bell. edit to say is the case of the 2.8 T9 variant the same as the 2.0 T9 variant?
Anyone care to suggest a better product (for c£1000) or advice on the above?
And yes I've got a T9 with 24k on it sat in the garage but it aint gonna last long so seems pointless for the effort of swapping only to swap again after a few hundred miles when that gives up the ghost.
Ta muchly.
[Edited on 23/7/07 by Pants On Fire]
Yes, I am an agent of Satan, but my duties are largely ceremonial.
posted on 23/7/07 at 02:33 PM Reply With Quote
get yourself a Toyota W58 from a Celica or Supra. Should be cheap to buy and then spend the lump on a bellhousing and getting it in the car.
People use them with Chevy V8's so well up to the power.
There is a picture of it in this thread;
http://www.locostbuilders.co.uk/viewthread.php?tid=50797
graememk
posted on 23/7/07 at 03:33 PM Reply With Quote
i have a nissan box from a 200sx in my indy
and people put them up to big bhp
Volvorsport
posted on 23/7/07 at 06:11 PM Reply With Quote
a getrag with a detachable bellhousing , would take the power , but the ratios are crap , read 1st is too low for serious work .
a T5 (cossie box) will definitely stand upto that power , have good ratios , and parts are available from quaife .
if you look further affield ie the states pick up a v8 t5 - 2.9 first , for about $300 dollars , shipping is the killer .
www.dbsmotorsport.co.uk
getting dirty under a bus
jacko
posted on 23/7/07 at 06:49 PM Reply With Quote
Hi will a Nissan 200sx gear box fit to a ford pinto engine? and how big is a 200sx box to a type 9
Jacko
