robertst
| posted on 25/7/07 at 01:07 AM |
clutch
been recently to the ford dealers to get me a clutch kit (friction disc, pressure plate, bearing) and they wanted almost 300€ for it!!
that IS a rip-off isnt' it?
i currently have a worn friction disc and according to the advice given here to me about a stiff clutch pedal, i should also change the pressure
plate...
is it cheaper for me to get these from the uk and ship them to spain?
Tom
UncleFista
| posted on 25/7/07 at 01:44 AM |
£50 delivered (to Spain) from
HERE although if you want a named brand it may cost a few quid more.
It's worth going to the main dealers for a price, then when you get it for a fraction of their price, you can pat yourself on the back
Tony Bond / UncleFista
jollygreengiant
| posted on 25/7/07 at 04:25 AM |
Genuine Ford clutch's are in reallity made by a company called LUK, so you need to find a uk company that will post you out a LUK clutch. I
bought one once from the dealer and it was £120 in about 1988. The same clutch from LUK through a wholesaler was about £90. So shop around.
Macbeast
| posted on 25/7/07 at 04:58 AM |
Burton Power (not normally considered to be the cheapest) catalogue shows 2L Pinto clutch kit at £77.95.
WWW.Burtonpower.com for on line sales.
I paid about £80 from my local parts factor this year.
| posted on 25/7/07 at 06:24 AM |
Going rate is about £45 +Vat + delivery
Try a Google for BuyPartsBy
edspurrier
| posted on 25/7/07 at 08:48 AM |
Obsolete Ford Parts do Pinto clutch kit for £11
mcerd1
| posted on 25/7/07 at 09:25 AM |
quote: Originally posted by jollygreengiant
Genuine Ford clutch's are in reallity made by a company called LUK, .... was about £90.
I've just got a LUK one, I think it cost about the same - the stock car boys use them so they must be good enough
(I don't know the exact price as I got it with a whole pile of bits and had it and the flywheel balanced all at once)
quick google search found this:
http://www.luk.de/content.luk.de/en/regions/region-europe.jsp?url_ok=..%2F..%2Fen%2Fregions%2Fregion-europe.jsp&country_id=6019&location_
id=6375&view_images=true&attribute_id=OEM&attribute_id=Aftermarket&attribute_id=Service&continent_id=39&submitted=Display+sele
ction&
[Edited on 25/7/07 by mcerd1]
robertst
| posted on 25/7/07 at 11:10 AM |
thanks guys.
the price difference is so large, it makes me think the dealers just pump up the prices for no reason... i'm kind of worried as i just ordered a
full set of engine joints, gaskets, bolts..   its gonna cost me an arm!
Tom
mcerd1
| posted on 25/7/07 at 12:06 PM |
I think you need to find out where your local garages (not main dealers) get there parts from
here in Edinburgh we have 'pentland components' for most bits, alot cheeper than any of the dealers - there must be somewhere like that
near you ?
quote: Originally posted by robertst
i'm kind of worried as i just ordered a full set of engine joints, gaskets, bolts..   its gonna cost me an arm!
what bolts did/ do you need ?
robertst
| posted on 26/7/07 at 11:45 AM |
head and flywheel bolts
Tom
mcerd1
| posted on 26/7/07 at 12:40 PM |
you should be able to reuse the head ones unless they are damaged
as for the flywheel, burtons sell HD ones and you can get ARP race spec ones too (might be more expencive than ford)
robertst
| posted on 26/7/07 at 04:30 PM |
i thought once they were torqued up they couldnt be re-used. they're the torx stretch bolts...
Tom
mcerd1
| posted on 27/7/07 at 02:02 PM |
Thats what i thought too, but according to the guy who did the work on my engine they reuse them all the time no problem (they mostly build 2.0 pinto
stock car engines)
but if you don't trust them then I suppose the new ones won't hurt - i might still use new ones on mine
the flywheel ones have been known to shear on tuned engines
so you could get heavy duty or ARP bolts or better yet get the flywheel dowelled onto the crank
or the like me get a cosworth crank [9 bolts instead of 6] and a pinto steel flywheel with cossie bolt holes or a lightened cossie flywheel [has a
bigger clutch], but this is not the cheep option
