SALAD
| posted on 27/7/07 at 07:17 PM |
Weber Venturi's?
I've read that my engine (XE) won't be able to rev past 6000rpm on my DCOE 40's.....so, is it possible to up this rpm limit by
changing the choke's/venturi's for larger ones?
I do need to see what are actually in there now, but am I correct in thinking that the largest you can fit in 40's are 33mm?
I know it would be better to go to twin 45's, or even ditch the webers and go bike carbs or throttle bodies but I have these carbs and they are
in amazing condition so I want to give them a run if only just to hear them!
What do you think?
jamesbond007ltk
| posted on 27/7/07 at 07:23 PM |
You can get 36mm chokes for DCOE 40s
HTH
Rich
PS
Here;
http://cgi.ebay.co.uk/WEBER-40-DCOE-CHOKE-TUBES-SIZES-28-30-32-34-36mm-NEW_W0QQitemZ8073702364QQihZ019QQcategoryZ122139QQtcZphotoQQcmdZViewItem
Sorry, one day I'll learn links!!!
[Edited on 27/7/07 by jamesbond007ltk]
SALAD
| posted on 27/7/07 at 08:41 PM |
Thanks Rich. Do you think that even with 36mm chokes it won't be enough?
I guessing that is the case otherwise the reccomendation/option would be to change to the biggest chokes rather than to 45 DCOE's.
jamesbond007ltk
| posted on 27/7/07 at 09:29 PM |
Not an engine i am familiar with to be honest. but the principles ar still the same. If you can run tuned pintos and zetecs on 40s with the right
jets, chokes etc. Then you should be fine on an XE.
Sorry not to be anymore help.
Rich
jamesbond007ltk
| posted on 27/7/07 at 09:33 PM |
This may provide some inspiration, and a dent in your bank balance!
http://www.wilcoxengines.demon.co.uk/vauxhall.htm
They will no doubt be able to advise you of your jetting/choke requirements if yoo drop them a line
SALAD
| posted on 27/7/07 at 09:38 PM |
Yeay shiny bits, nice!
I'm still trawling through loads of XE info....got to do my homework!
Thanks for the input Rich
