Shamrock GS
| posted on 28/7/07 at 09:53 AM |
PINTO - Engine oil vent connection?
I have a 2l pinto fitted with twin 40 webbers. Under the carbs is an outlet which according to the Haynes manual is an engine oil vent. I presume this
would connect to the original ford carb.
My question is what do I do with it? Should I connect it to somewhere else and if so where?
Gary
Sun Tzu, The Art of War
nitram38
| posted on 28/7/07 at 09:58 AM |
Are you sure that it is not a vacuum take off for a the brake servo?
How about a photo?
[Edited on 28/7/2007 by nitram38]
antonyg
| posted on 28/7/07 at 10:24 AM |
i have the same set up as you
yes it does connect to the original carb
what you need is a breather elbow burton power sell them part No FP280 for £7.50
then you can take a pipe from this to a catch tank, this is what i have done
Hope this helps
Antony
2b_pablo
| posted on 28/7/07 at 11:27 AM |
http://www.locostbuilders.co.uk/viewthread.php?tid=70692
lots of info there mate
Shamrock GS
| posted on 28/7/07 at 12:38 PM |
Great advice folks - thanks
Gary
Shamrock GS
| posted on 29/7/07 at 09:11 AM |
I am told that if I simply use a Pipercross filter attached to the vent with a pipe this will get rid of any need for a catch tank - does this sounmd
right?
Gary
2b_pablo
| posted on 29/7/07 at 09:57 AM |
technically why bother with the filter?
| posted on 29/7/07 at 10:01 AM |
OK if you like rebuilding every 5 minutes as the particles in inducted air act like grinding paste!
2b_pablo
| posted on 29/7/07 at 10:07 AM |
what does the filter do tho versus just venting to air? Bar get clogged up with crap.
Ratters
| posted on 29/7/07 at 10:28 AM |
Is the air 'inducted' or vented out though??
| posted on 29/7/07 at 10:50 AM |
Stops crap getting back into the engine. And yes, they do get clogged up, which is why a catch tank is a much better idea.
2b_pablo
| posted on 29/7/07 at 11:18 AM |
With 40s its vented so I cant see why not having a filter allows crap into the engine. All a filter will do is catch the thicker crud that would
otherwise fall on the floor.
DarrenW
| posted on 30/7/07 at 08:52 AM |
Somebody got confused between air intake filters before the carbs and crankcase breather filters.
On my 38DGAS ive just blocked off the crankcase vent inlet on the carb manifold.
| posted on 20/11/07 at 11:41 AM |
Venting your oil onto the floor (i.e. the road) is very poor practice ineed and potentially lethal for the bikers amongst us (I'm not a biker
BTW). Either recirculate via combustion (as OEMs do) it or catch it in a tank and dispose of properly.
Nick
2b_pablo
| posted on 20/11/07 at 11:47 AM |
agreed, I use a catch tank with no filter. the vapour is free to go where it wants
I wouldnt suggest letting waste oil run onto the road. Just worded it badly above.
