Author: Subject: removing bike engine sprocket
dan__wright
posted on 30/7/07 at 10:02 AM Reply With Quote
whats the best way to do the above? service manuals say sick the rear brake on and undo it but as the engine isnt in a bike i cant do that.
im going to give it a go with mole grips on the sprocket and see if i can get it off that way but am a little bit doubtful that will work. only other option i can see is put it in gear but dont want to damage the box.
FREE THE ROADSTER ONE…!!
Coose
posted on 30/7/07 at 10:04 AM Reply With Quote
Put it in first and use a windy gun (or electric equivalent). You won't break the box....
Spin 'er off Well...
Confused but excited.
posted on 30/7/07 at 10:07 AM Reply With Quote
Make a chain wrench to fit around the sprocket. That's what we used to do many moons ago.
dan__wright
that was the first thing that came into mine any my mates head but im paranoid il strip something.
Coose
posted on 30/7/07 at 10:38 AM Reply With Quote
Oh believe me, you'd have to be properly cack-handed to do any damage!
mistergrumpy
posted on 30/7/07 at 11:48 AM Reply With Quote
I made like a Y shaped bracket to hold the sprocket then got the engine into 2nd gear and used a masive breaker bar.They're on real tight.Not to teach you to suck eggs but you have noticed the washer with the bent up sides haven't you?
tks
posted on 30/7/07 at 11:56 AM Reply With Quote
:D:D
is your airgun 100BHP???
how would you damage the box??
only thing i can imagine is the engine spinning arround...
i would use a piece of chain... welded to a long bar.
Tks
[Edited on 30/7/07 by tks]
dan__wright
posted on 30/7/07 at 12:09 PM Reply With Quote
havent started yet but yes have bent the washer back.
i know its nowhere near as powerfull as the engine but 1 its going to oposite direction and too there is the imact aswell.
cloudy
posted on 30/7/07 at 12:23 PM Reply With Quote
I took mine off last week purely by sticking in first and undoing with a spanner - they are not generally hugely tight I think
James
nitram38
posted on 30/7/07 at 02:27 PM Reply With Quote
With my R1 in neutral I wedged a bit of wood between the sprocket and the case and used my battery impact driver on it.
It came off really easy.
The R1 has a Tab washer that has to be released first though!
[Edited on 30/7/2007 by nitram38]
dan__wright
posted on 30/7/07 at 06:35 PM Reply With Quote
pair of molegrips pushing against the engine cradle and a screwdriver though the hole in the sprocket, quick blast of the impact gun and its off
Coose
posted on 30/7/07 at 06:57 PM Reply With Quote
Splendid!
