| posted on 30/7/07 at 02:33 PM |
?? need to oil choke cables
I jumped in the LocoPan the other day and the choke cable has seized solid.... I suspect it was after driving home in the pi$$ing rain with the
bonnet scoop acting like rain scoop, directing vast amounts of precipitation onto the carbs (+ hence choke cable)
Do choke cables usually need oiling to keep them working nicely or was the cable I found in my parts bin just a cheap+nasty rust-loving cable????
I'm going to replace it but want to know how to prevent it from happening again-
a) better cable
b) more oiling
cheers
Coose
| posted on 30/7/07 at 03:09 PM |
Buy a £4 cable oiler and squirt a bit of WD40 down there. It works for me!
Spin 'er off Well...
Coose
| posted on 30/7/07 at 03:10 PM |
Here we go -
DIY Si
| posted on 30/7/07 at 03:29 PM |
Last time I did it, I used some ptfe/white grease I think. Seemed to work a treat and never appeared to go off/get stiff either.
Sun Tzu, The Art of War
mark chandler
| posted on 30/7/07 at 06:24 PM |
Undo the carb end, make a small plasticine funnel over the end of the sleeve to direct oil into the middle, hang up then fill with oil and leave
overnight.
Regards Mark
