andy o
posted on 3/8/07 at 02:00 PM |
lamda sensor
hi,anybody know the thread size of a lsu 4.2 sensor?does make a stainless boss which i can weld on?is this wideband?
thanks andy
Agriv8
| posted on 3/8/07 at 02:06 PM |
bought bosses from 'Nick Skidmore' who is on here as for the tread size M18 but could be wrong
Stainless with bung .
Send him a U2U
Regards
Agriv8
SeaBass
| posted on 3/8/07 at 02:29 PM |
Take your pick...
Fatboy Dave
| posted on 3/8/07 at 02:47 PM |
M18x1.5
Dave
Stop the planet, I want to get off
matt_claydon
| posted on 3/8/07 at 02:51 PM |
It is wideband, and it's a standard Lambda sensor thread (whatever that is!). You do know a wideband has to be used with a suitable controller
such as the LC-1? You can't just plug it into your ECU.
Edit: There may be some ECUs with built-in controllers but if so they're not the norm.
[Edited on 3/8/07 by matt_claydon]
Agriv8
| posted on 3/8/07 at 02:59 PM |
I agree - but for info Vems has the conroller on board - ( including the settings to calibrate !!! )
Complete shamless plug I know but hey its friday
Regards
Agriv8
tks
| posted on 3/8/07 at 03:18 PM |
its the same thread as a sparkplug i'm told..
also maybe some exhasut suppliers can supply easyly an weld on boss, anyway i brought them also from Nick
matt_claydon
| posted on 3/8/07 at 03:36 PM |
Thought it might have been VEMS
andy o
| posted on 3/8/07 at 03:49 PM |
lamda
thanks for all that,
i,m using a 1.8 raceline zetec with jenveys
and im thinking of using megasquirt.the sensor has a 6 pin plug on it with a little blackbox plugged into that,is this the lc-1 or will megasquirt
sort that?
matt_claydon
| posted on 3/8/07 at 04:25 PM |
That probably is the lc1. Should look like this:
907
| posted on 3/8/07 at 04:43 PM |
I've got one.
M18 x 1.5 x 17mm long.
It's a left over from when I made my wish bones
hth
Paul G
(p.s. I'm 40 mins from Cambridge)
andy o
| posted on 3/8/07 at 04:55 PM |
i don't have the wiring as shown in photo
after it plugs together i.e the long black bit.
is that the lc1
thanks
matt_claydon
| posted on 4/8/07 at 08:18 AM |
Yes, the long black case is the LC-1 controller. That then gives a (programmable) variable voltage output (usually 0v = 10:1 AFR, 5v = 20:1 AFR) to
your ECU.
I bought mine from diyautotune.com and had it shipped over from the states. Even with import tax it was the cheapest option at the time with the
current exchange rate.
