Author: Subject: fitting a new engine
graememk
posted on 4/8/07 at 11:00 AM Reply With Quote
herrrm woops, giving the car a bit of beans last night off the roundabouts and lights giving the boy racers a laught i think i might pressed the loud peddle to hard
lucky for me i have a spare engine as this one has a con rod hanging out the side of it
mental note red line is now 6k not 7k lol woops
that should teach me not to tw4t around with the turbo bleed valve.
should be an easy swap i think, i heard the other engine running and intended to recon it before fitting but now i might just drop it in lol.
posted on 4/8/07 at 11:06 AM Reply With Quote
Bad luck old chap!
Bad choice of weekend to be sans Locost....
CaptainJosh
posted on 4/8/07 at 11:11 AM Reply With Quote
Thank you for posting this! Now people will believe me when I say turbo's will make your engine break
Not saying you shouldn't have one but maybe a little less boost next time
graememk
posted on 4/8/07 at 11:18 AM Reply With Quote
i was going to change it in the next few weeks anyway as it was getting tired and i want my mate to set the mega squirt up properly so it needed doing and i was driving it like a to55er knowing that it was going to get changed.
so i've got to be at church at 11 in the morning so i think i can get it chaged before tomorrow evening......
best not go to the pub tonight
MkIndy7
posted on 4/8/07 at 11:42 AM Reply With Quote
Hmm if the exisiting engine was in a similar condition i.e a bit weak, maybe you'd be better off re-conditioning this one before you put it in.. or certainly consider it over the winter period otherwise it might quickly go in the same direction leaving you with 2 knackered blocks
graememk
posted on 4/8/07 at 11:59 AM Reply With Quote
going to replace it with a sr20 out of a 200 sx
thats the winter mods, although i have been thinking about r1's as well
clutch_kick
posted on 4/8/07 at 12:47 PM Reply With Quote
A really strong turbo engine would be the 1.4L 8v, that came with the Fiat Uno turbo and the Punto. I've seen it run 1.8Bar boost, with just a little compression drop to help, and a ball bearing turbo. Goes like a rocket.
graememk
posted on 4/8/07 at 01:24 PM Reply With Quote
1.4 lol need more horses than that
pmsl
locoR1
posted on 4/8/07 at 08:12 PM Reply With Quote
Bad luck M8, have you go a boost gauge or was it a case of a bit more and a bit more,more,more,more,more "Bang" lol
Put an R1 in it and go bec you know it make sense you could always turbo that then!!!!!!!!!!!
dave............................
Check out my CB500T Cafe Racer build diary
graememk
posted on 4/8/07 at 08:16 PM Reply With Quote
just kept turning it up for a laugh lol
locoR1
posted on 4/8/07 at 08:20 PM Reply With Quote
I had a feeling you would say that lol
Do you know what boost it held before it went pop? Or are you just going to back it of a bit for the next engine
graememk
posted on 4/8/07 at 08:53 PM Reply With Quote
22psi lol i was told not to run it over 14psi and about 10 - 12psi normal driving
6psi was standard
it had to be done the old engine was a bit noisy anyway.
[Edited on 4/8/07 by graememk]
NS Dev
posted on 5/8/07 at 12:11 PM Reply With Quote
to be fair it won't have been the boost that broke the rod unless it forced a bearing to pick up, more likely due to sustained revs
