john_p_b
| posted on 5/8/07 at 02:48 PM |
twin 40's, do i need a fuel return pipe?
well after mucho time messing about i finally the other day got around to fitting my facet fuel pump, all very good but i'm stuck with 1 thing.
on the original ford set up it goes tank to pump, pump to regulator then from the regulator there's 1 line off to the carbs and 1 a return to
the tank, simple.
but running with the facet pump and filter king regulator i have no return line? is it a case i don't need a return line now i'm on a
electric pump or am i going to have to modify more parts to suit?!
thanks in advance for any help given.
built a car, built a home, had a family. lost the family, lost the home, still got the car.
| posted on 5/8/07 at 02:51 PM |
If you have a fuel pump intended for carbs you don't need either a regulator or a return line.
john_p_b
| posted on 5/8/07 at 02:52 PM |
it's a facet silvertop pump, but i was told these run at around 7psi and my webers only like around 4psi?
mookaloid
| posted on 5/8/07 at 02:55 PM |
The flter king regulator can be adjusted to give the correct pressure
john_p_b
| posted on 5/8/07 at 02:58 PM |
so no return line required then?
flak monkey
| posted on 5/8/07 at 02:59 PM |
No return needed. Just a regulator for the pump. You should need about 2-3.5psi for webers and plenty of fuel volume!
Sera
http://www.motosera.com
mookaloid
| posted on 5/8/07 at 03:01 PM |
My set up is just as you have described yours and it works fine so no you don't need one
caber
| posted on 5/8/07 at 04:31 PM |
Ditto I have twin 40s Fuel King and a Pacet pump which stops running when the Fuel king closes. All works nicely, just need to set the carbs up and
fix the exhaust!
Caber
| posted on 5/8/07 at 06:20 PM |
Always amazes me why builders have to complicate fuel systems.
Why buy a high pressure pump in the first place.
john_p_b
| posted on 6/8/07 at 05:18 PM |
the simple answer to the above would be it was cheap
| posted on 6/8/07 at 06:16 PM |
Main problem with regulators is regulator can only work by shutting off the flow.
Other problem with regulators is they tend not to work in a no flow situation, comming from a marine engineering steam ship background not to trust
pressure regulators was hammered into me.
With a sytem with a proper return line it a different matter.
The presure in a fuel line on a carb engine should be determind by the internal spring fitted to the pump.
