minidoido
posted on 5/8/07 at 03:01 PM |
Engine exhaust - Help needed
Hi!
Tried the exhaust on yesterday, and found out that it's to close to the servo.
[img]/upload/IMG_1715.jpg[/img]
[img]/upload/IMG_1721.jpg[/img]
What can I do? Any ideas?
I was thinking of building a new exhaust or at least a heat shield. But I don't think the heat shield would be enough.
Does anyone have a exhaust design for an Escort 1.3 GT engine?
Thank you.
[Edited on 5/8/07 by minidoido]
mookaloid
| posted on 5/8/07 at 03:03 PM |
Bin the servo - you don't need it and it adds weight
RazMan
| posted on 5/8/07 at 04:02 PM |
I have to agree - why use a servo on a car that is probably less than half of the weight?
Raz
| posted on 5/8/07 at 04:35 PM |
The picture in your archive shows it near the fluid reservoir. I would change the pedal arrangement to move the master cylinder out of the way or make
a manifold that goes over the top chassis rail. Left hand drive causes its own set of problems.
Chippy
| posted on 5/8/07 at 09:50 PM |
Why not just fit a remote reservior, and pipe it down to the MC. Ray
matt_claydon
| posted on 6/8/07 at 07:24 AM |
That's the fluid reservoir, not a servo. As above, just fit a remote reservoir to the master cylinder - problem solved.
minidoido
| posted on 6/8/07 at 09:24 AM |
Hi!
Thanks for the help!
I will try to put a remote reservoir. I have no idea how that one comes out, but I think you just have to pull it off.
About the exhaust, does anyone have a design or picture of a manifold that goes over the top chassis rail.
