Deckman001
| posted on 12/8/07 at 04:45 PM |
Rad in nose cone sealing ??
Hi all, what have people used to seal around the radiator filling the gap between it and the nose, I've got a hinged cone so need it to be
pliant
Jason
| posted on 12/8/07 at 07:44 PM |
Expanding foam that is used for sealing around household pipes etc. Be careful as it expands a lot... cover the Radiator with plastic first and be
prepared to do some cutting to release it as it doesn't half hang on!!!
Deckman001
| posted on 12/8/07 at 08:42 PM |
cheers Steve, I think that solution would hinder my flip front nose cone, it's hinged at the lower front point allowing it to rotate forward
and get gravel rash if I forget to do up the Dzus fastners
Now the bonnet is fitted that last senario shouldn't happen to often
Jason
Deckman001
| posted on 12/8/07 at 09:19 PM |
I was thinking of some sort of rubber strip, maybe some DPM ??
Jason
