samwilliams
| posted on 13/8/07 at 09:33 AM |
Broken radiator - what do I need?
Sadly at the moment I seem to be making quite a few posts asking "this is broken, please help". Well, this is another of them!
My radiator decided that keeping water in was a bit boring for it the other day, and proceeded to spray it everywhere. Therefore, I think I need a new
one (don't think it's even worth trying radweld or something like that).
Because I was lazy and bought my car, rather than built it, I don't know what the radiator is from. I've stuck a picture in my archive.
Does anyone have any suggestions? (If it helps, it's a sylva phoenix).
Thank you (again!!)
Sam
locoboy
| posted on 13/8/07 at 09:38 AM |
Dont worry we all break thing!
  Broken radiator
Looks like the old ford one that was in my Formula 27, possibly Cortina not sure though.
I would go for a more modern ally one if i were you.
It looks like your not pushed for space so your choices shouldnt be 'that' limited.
Locoboy
| posted on 13/8/07 at 09:42 AM |
If the radiator worked and kept things cool get it repaired or fit a Mk1 Polo rad which is a common alternative.
| posted on 13/8/07 at 10:00 AM |
It deos look like cortina one.
You don't say where you are but I have one, ondition unknown but looks sounds for a couple of quid or free - depending on how generous you feel
that you would need to collect.
regarding repair - have a look inside - is there much build up of crud? and are the copper fins sound or beginning to fall apart? it may noe be
worth it if it needs a recore - the top and bottom you vould do yoursellf with blow lamp providing you are careful not to melt the core joins.
as ^^^, a moderan aluminium one would be better and you can fit a bigger one as you have plenyt of space - but note they usuallly don;t have a
radaitor cap so you would need an expansion tank.
I wouldn;t use radweld but have read that folks have and it has lasted well.
samwilliams
| posted on 13/8/07 at 10:06 AM |
Thanks for the suggestions. I'm in Central London. Any recommendations for places near me to fix it or get a new one? Been looking on the
internet and come across a few places, but any recommendations would be marvellous.
Sam
| posted on 13/8/07 at 01:41 PM |
It a 70s Ford rad --- Escort or Capri or Cortina all pretty much the same.
Difficult to tell from the picture but I think it has been modded with the top tank removed and bottom tank fitted in its place to do away with the
filler cap.
Either fit a more modern rad (Mk1/Mk2 Polo) or get it re-cored
However if you want to try and seal it use K-Seal -- Avoid Radweld or Barrs Leaks.
