Author: Subject: Pinto Oil Pump Removal
rpsmith
posted on 15/8/07 at 12:16 PM Reply With Quote
What is the correct socket / tool to remove the oil pump from a Pinto engine, in the Haynes manual it says use a suitable splined socket, but i tried my range of Torx sockets and none seemed to be the right size, i tried the nearest size but it just slipped and removed a couple of the slines from the bolt
Fatgadget
posted on 15/8/07 at 12:48 PM Reply With Quote
Spline and torx are completely different. Should be able to get a suitable spline tool from Halfrauds if you mention what it's for.
flange nut
posted on 15/8/07 at 12:57 PM Reply With Quote
IIRC what you need is a M6 spline bit.
Geoff
rpsmith
posted on 15/8/07 at 01:40 PM Reply With Quote
Ahhhhhh, cheers guys
