SyKaTurbo
| posted on 17/8/07 at 09:41 AM |
Vauxhall - Type 9 Bellhousing
Does anyone produce these other than SBD? Would also need a new clutch combo so what are you Vaux engined guys using?
Simon
DarrenW
| posted on 17/8/07 at 09:49 AM |
Yukspeed do the 2 different angles ones. Also list sumps in kit form on their site. Not sure if these are only for XE 16V though or not.
chrsgrain
| posted on 17/8/07 at 10:04 AM |
The omega boxes bolt straight to a C20XE, have good ratios and are pretty tough. Also hydraulic concentric clutch... very straightforward...
Chris
omega 24 v6
| posted on 17/8/07 at 03:16 PM |
Various places
SBD
Yukspeed
A frame engineering (got mines here)
A lot of others if you search will prolly have them.
Mr G
| posted on 17/8/07 at 06:28 PM |
Remeber there are 2 different lengths as well as 2 different engine angles so 4 options in total.
You've got standard input shaft length and then V6 (+25mm) box length.
Most common will be upright and standard type 9 input shaft length. Then if you wanted to fit a V6 box for its ratios at a later date all you'd
need is a 25mm spacer.
Pressure plate is the original vaux item and friction plate is Ford 1" spline jobbie. 2.3 diesel a common choice iirc
Edit: Noticed your putting the 1600 16v in so not sure on the situation with the flywheel/pressure plate/friction plate options compared to the
2.0XE
Standard ford spigot bearing needs to be hammered home into the end of the crank - from main dealer or motor factors etc.
[Edited on 17/8/07 by Mr G]
NS Dev
| posted on 17/8/07 at 07:58 PM |
yep wot he said, except that you can also use a std vauxhall spigot bearing which is the same size.
1600 16v is same bellhousing pattern but no idea on clutch bits
chriscook
| posted on 18/11/07 at 03:17 PM |
Has anyone got the Ford or Vauxhall part number for the spigot bearing please?
Thanks,
Chris
