Poll: Engine rebuild? [View Results]
New Engine
Shop rebuild
I did all but the machining
I did it *ALL*
No recondition - known donor
No recondition at all
Author: Subject: Engine rebuild?
kiwirex
posted on 7/9/03 at 08:58 AM Reply With Quote
Engine rebuild?
Hi Guys,
Wondering how many folk have just dumped their donor engine in and who's had a rebuild?
Thought I'd distinguish between an engine you know and one that comes with a new donor.
And how much time do you think it added to your build??
- Greg H
posted on 7/9/03 at 10:17 AM Reply With Quote
Mine drove home OK so i'm using it as it was. Haven't started it yet though.
Will give it a fiddle when the car is finished, to sort any problems encountered.
That is one benefit of using a running donor!
Mark Allanson
posted on 7/9/03 at 11:26 AM Reply With Quote
Don't fix what ain't broke!
My motor does need new valve stem seals so I am going to recon the head, the bottom end is fine with 190psi in all four cylinders. It is a good idea to check everything before you remove the engine, especially a compression check, wet and dry
craig1410
posted on 7/9/03 at 11:37 AM Reply With Quote
Engine is from known source and was supposed to have been rebuilt less than 10k miles ago so just using as is for now. Will most likely rebuild it again (top end at least) after it is on the road.
Craig.
macspeedy
posted on 7/9/03 at 12:23 PM Reply With Quote
Pinto rebuild
Engine was stripped checked crank re ground and balanced with rods, re bore and new pistons, also arp bolts for the rods. This work is cheaper than the head work and thats with me doing the porting! might as well start with a good bottom end. block was also ground as will the head be when its had 3 angle seats cut by the machine shop, matched the ports on the head with the inlet manifold and blended the valve stem supports in the ports, ports were not polished but were ground to smooth in valve seat area. engine will be run in using running in oil, this replicates the wear and beds everything in nicely in a 50 min dyno run, then its new oil and into the car ready to rolling road tune once its passed its SVA!
