mongrelwestie
| posted on 26/8/07 at 04:03 PM |
Cooling system on a 2.0 zetec without heaters?
just trying to work out where the pipes go on the thermostat housing, got the obvious ones but need some final help, does anyone have a diagram or any
good pictures of there set up?
any help would be apretiated
| posted on 26/8/07 at 05:55 PM |
Looks a little different to mine. Mine doesn't have that hose coming off the top of the main outlet.
Under the main outlet there is another small pipe that needs to go to the bottom hose. Its a thermostat bypass for when the engine is cold and helps
towards a quick warm up.
The other outlet at the back goes to the heater.. if you have one, otherwise block it off.
mongrelwestie
| posted on 26/8/07 at 06:14 PM |
what goes to the bottem of the overflow tank?
fideel109
| posted on 26/8/07 at 08:01 PM |
http://www.zetec-cat.co.uk/
http://www.toyne.org.uk/docs-cooling.html
Ford Zetec cooling diagram is explained on this site, was very helpful for me.
Rgds-JP
SeaBass
| posted on 26/8/07 at 08:11 PM |
I used this to plumb in a Black Top. No problems so far...
http://www.emeng.gentlyhosting.co.uk/Cooling/Part1.htm
paulf
| posted on 26/8/07 at 09:06 PM |
Tee it into the one from under the main outlet that connects to the bottom hose .
Paul.
mongrelwestie
| posted on 27/8/07 at 08:48 AM |
thanks for the help, that should make it easier when the radiator arrives on wednesday
muzchap
| posted on 27/8/07 at 10:03 AM |
This should help - also check my pic archive for some pics of it actually on the car.
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
edspurrier
| posted on 27/8/07 at 07:12 PM |
I followed the Toyne diagram - but instead of runing two pipes forward to the bottom ali pipe, because not using a heater, I've T peiced the
heater and bottom thermostat outlet together so there's some flow where the heater would be.
Not tried it yet though!
