the moa 2
| posted on 27/8/07 at 10:38 PM |
Pressurised or non pressurised system
Just when we think weve sorted this water system it goes and pops another hose off on us after reaching 90 degrees.
We managed to run the engine get it up to 75 degrees drove the car around our estate which put big smiles on our faces the temp held and even dropped
when moving as we had the fan and water pump set on maximum capacity.
We have a ZX12-R with an electric water pump a polo radiator and header tank system with a Stant radiator cap 21-25 lb.
The reason i originally got this cap was after hearing some folks on here with a ZX12-R having problems with the cap continually blowing which was due
to have too lower rated cap. But we cant seem to even get to blowing the cap, this may be to a badly plumbed system which were currently trying to
improve .
What i wanted to try was to run a rad cap with a very low pressure rating and then have the overflow expand to a tank would this work , Or must i run
a pressurised system ?
To note we have bled the system and am fairly sure that there wasn't any air locks.
Any help much appreciated.
nitram38
| posted on 27/8/07 at 10:52 PM |
Do your solid pipes have a ridge to hold them on?
90 degrees sounds too low to blow hoses off unless the clips aren't holding them on properly in the first place.
RazMan
| posted on 28/8/07 at 06:29 AM |
Are you sure that the temp is only 90 degrees when the hose blows off? You might be running hotter than you think - either that or you have a hot spot
somewhere.
[Edited on 28-8-07 by RazMan]
Raz
the moa 2
| posted on 28/8/07 at 08:10 AM |
the hose that blew didnt have a beed which is what we are trying to sort now .
Pretty sure temp is correct as have two points to check my water pump controller which has a thermo placed in the engine block and my dash mounted
temp gauge.
