Dick Axtell
posted on 8/6/02 at 03:27 PM |
Engine mounts - location
Feedback invited from all who have successfully fitted their engine + g/box.
A: MK live axle type chassis,
B: 1600GT X-flow + capri 4s g/box,
C: Lluego x-flow engine mounts.
A + B + C = Won't bl**dy fit!!
Existing chassis mounting holes approx 520mm apart; rubber bobbin studs approx 450mm apart. Solution appears to require 2 new holes.
Anyone else encountered this "anomaly"? What was your solution?
Dick
phil m
posted on 9/6/02 at 07:51 PM |
Dick ,
at the same point as you -are the mounts too wide for the chassis- as positioning my engine this looks like a potential problem
Phil
Dick Axtell
posted on 10/6/02 at 07:00 AM |
Hi Phil -
In my case, the new mounts' spacing is too narrow for the spacing on the chassis plates.
Still reckon drilling new holes will be necesary.
Dick
