Author: Subject: oil pump shaft size?
jabbahutt
posted on 30/8/07 at 08:17 AM Reply With Quote
Morning
Anyone happen to know what size socket fits the oil pump shaft so I can try giving it a spin with an electrical drill.
Nigel
ash_hammond
posted on 30/8/07 at 08:31 AM Reply With Quote
7mm i think.
Sounds like i am not the only one having PINTOSAURUS oil pressure problems!
- Ash
.: www.mac1motorsports.co.uk | www.m1moc.com :.
jabbahutt
posted on 30/8/07 at 08:34 AM Reply With Quote
Ash
sorry to hear you're hjaving problems though it it nice to know I'm not on my own
What problem have you got with oil pressure.
posted on 30/8/07 at 08:38 AM Reply With Quote
use a cordless for saftey reasns, at lowest speed.
v8kid
posted on 30/8/07 at 11:17 AM Reply With Quote
Make sure you don't burn the drill out - mine started smoking!! Ended up using a corded drill on low mechanical speed
ash_hammond
posted on 30/8/07 at 11:50 AM Reply With Quote
was running low oil pressure on start up - now she does not seem to have any pressure at all. Nothing to worry about SVA is only in 5 days
jabbahutt
posted on 30/8/07 at 12:44 PM Reply With Quote
good luck with the SVA and the oil pressure
MkIndy7
posted on 30/8/07 at 04:26 PM Reply With Quote
Probably a stupid question but have you checked the end oil pick-up pipe?
Where ours was shortened, the pickup pipe was toutching the Gauze on the end of the cone, instead of being furth up inside the "funnel" shape, so the slightest of debris could block the end of the pipe, as the pickup pipes was only drawing on the diameter of the pipe rather then the diameter of the funnel.
We also dinted the sump outwards slightly with a big socket to create a deeper part of the sump for the pick-up pipe to sit in and to make sure there were no clearance issues.
jacko
posted on 30/8/07 at 04:44 PM Reply With Quote
Have you got a modified sump? you need 8-10mm clearance between pickup pipe and sump also has the pipe got a good seal to the pump if not it will not suck the oil up the pipe
Sorry if you know this
Jacko
jabbahutt
posted on 31/8/07 at 07:23 AM Reply With Quote
thanks for the extra input on the the last two posts fellas. I'm aware that the pick up pipe installation could be the problem either with clearance at sump bottom or not sealing to pump properly.
As you can imagine I'd like to remove all other options before dropping the sump as it was a bit of a mare installing with only two hands on an engine stand (cork and rubber sealing strips keeping still) so you can imagine I'd rather not go there with the engine in the car until I've ruled out the other options first. The
Many thanks for the input. I hope it isn't a pick up pipe/sump problem as both were modified by tiger racing so I'd hope they'd done a proper job. Though I hadn't a clue how to test it without fitting it first. not the easiest to fit as the extra capacity makes fitting two to three of the bolts pretty awkward!!
Thanks again tonight and the weekend I'll test out all these and if the worst comes to the worst drop the sump
jacko
posted on 31/8/07 at 07:55 PM Reply With Quote
Hi if you do remove the sump evostick is your friend clean the block with degreaser and glue the gasket on the block it makes it a lot easier when fitting the sump
Jacko
