Author: Subject: Jag manual gearbox drain plug
speedyxjs
posted on 31/8/07 at 07:59 AM Reply With Quote
Does anyone know where the drain plug is for the xj40 manual gearbox?
I have the haynes manual but it only covers the auto.
I cant get under the car as im waiting for my new jack (should come today)
TGR-ECOSSE
posted on 31/8/07 at 10:52 AM Reply With Quote
Sorry i don't know where the dran plug is but i found the filler plug if that helps.
speedyxjs
posted on 31/8/07 at 11:04 AM Reply With Quote
Not really
I need to drain the gearbox oil before i undo the propshaft.
posted on 31/8/07 at 11:29 AM Reply With Quote
Not many gearboxes have drain plugs nowadays only filler/level plugs as there is not a change of oil specified for them. The oil usually drains out of the end when you tilt them with the prop removed . Plug the hole in the end if it's a push in prop and the oil should stay in.
[Edited on 31/8/07 by Peteff]
