Avoneer
| posted on 2/9/07 at 10:43 AM |
Prop Shaft Balancing weight fell off
Can I just araldite it back on in the same place (clearly marked) or is it more technical than this?
Pat...
omega 24 v6
| posted on 2/9/07 at 11:27 AM |
Your lucky still to have the weight and do you trust the glue to hold it?? If it were me i'd drill a hole in it and then puddle weld it to the
shaft and dress back flat so the weight was the same again
NS Dev
| posted on 2/9/07 at 01:12 PM |
yea weld it back on, a tack each end will do it or puddle weld, either way
tcr
| posted on 2/9/07 at 03:51 PM |
i take it you was'nt thrashing it when it came off, mine did at cadwell and the rear uj exploded at the top of the mountain
http://youtube.com/watch?v=UmFYFixyH44
MK MIDI ZX10R
http://www.facebook.com/media/set/?set=a.4393256076054.2182513.1427988207&type=1&l=64c91c3c17
why isnt anything simple!!!
torquetune.co.uk
nrpexhausts.co.uk
Avoneer
| posted on 2/9/07 at 04:05 PM |
Fortunately the prop didn't let go - just a weight came of.
Did notice this morning that the prop adaptor at the front had come loose as well!
Pat...
robertst
| posted on 2/9/07 at 04:12 PM |
WHOAA!!!! brown trouser moment!!!! is your tranny tunnel reinforced then? cos that prop must have been rattling everywhere inside there...
tcr
| posted on 2/9/07 at 04:33 PM |
Pat...
check EVERYTHING we found gearbox mounting had no bolts left ,
bellhousing-gearbox stripped 3out of 4 bolts,
bellhousing-engine only had 3 bolts left in it and front gearbox oil seal missing all in the space of half a lap.
yes the tunnel was reinforced so the prop diddnt do to much damage
[Edited on 2/9/07 by tcr]
MK MIDI ZX10R
torquetune.co.uk
nrpexhausts.co.uk
Avoneer
| posted on 2/9/07 at 04:53 PM |
Foget the prop, who's the dead guy you've just run over??????
Pat...
P.S. Cheers - in the process of checking everything.
tcr
| posted on 2/9/07 at 04:56 PM |
that would be me realizing how close i was to meeting the big man
MK MIDI ZX10R
torquetune.co.uk
nrpexhausts.co.uk
Avoneer
| posted on 8/9/07 at 05:03 PM |
This look ok or shall I grind dome off the welds?
Pat...
Avoneer
I nipped the cornes off the plate before welding.
Pat...
