Hammerhead
| posted on 3/9/07 at 07:50 PM |
trying to fit engine, should oil fall out gearbox?
I'm in the process of doing the engine and gearboxes first fit in the chassis, the problem is when I hoist the engine and gearbox (type 9) in
the air, a load of oil pees out of the splined end that joins the propshaft. Is this normal???
Any suggestions of what I should do?
cheers.
Steve.
omega 24 v6
| posted on 3/9/07 at 07:52 PM |
Normal fit a rubber glove over the end as th oils stinks and is messy
zzr1100rick2
quite normal drain the oil before you fit and then remember to fill before useing
blakep82
| posted on 3/9/07 at 07:53 PM |
mmm @ the smell of gearbox oil
yeah, it happened to me too. plastic bag over the end, or as said before rubber glove
________________________
Plug the hole . It does happen when the propshaft is removed, wad some rag in it or a dummy shaft.
stuart_g
| posted on 3/9/07 at 07:55 PM |
Happened to me too, quite normal.
Hammerhead
| posted on 3/9/07 at 07:58 PM |
bl00dy hell that was quick!
Thanks guys. My tin top stinks of gearbox oil because when I collected the gearbox from the guy who sold it to me, it leaked everywhere!!
great............might have to trade it in!
Thanks again.
snapper
| posted on 3/9/07 at 09:02 PM |
i use the old balancer and output shaft with as much of the balancer cut off then slid it of and slide in the prop quickly, very liitle oil lost.
I eat to survive
I drink to forget
Avoneer
| posted on 3/9/07 at 09:06 PM |
Cat wee !
Pat...
DarrenW
| posted on 4/9/07 at 08:04 AM |
quote: Originally posted by Avoneer
Cat wee !
Pat...
LOL!!!! i assume to mask the smell of the oil?????? Good tip
