Author: Subject: ZZR1100 Carburettors
r1_pete
posted on 6/9/07 at 10:38 AM Reply With Quote
Anyone have a diagram of the ZZR1100 carbs showing where all the pipes go? I understand theres a coolant path to heat the carbs.
Also where are the vac take offs? are they the screws underneath with plastic funnels round them?
Cheers.
Pete.
posted on 6/9/07 at 11:33 AM Reply With Quote
I've junked the coolant pipes as they are not really needed in a car.
The vacuum take offs are on the inlet rubbers.
posted on 6/9/07 at 01:00 PM Reply With Quote
The screws underneath are probably float drains.
DarrenW
posted on 6/9/07 at 03:26 PM Reply With Quote
Screws with funnels are indeed float bowl drains. I removed the heater pipes.
Are you sure about the vacuum take offs Coozey? i thought there wasnt any on the ZZR1100's.
Are you fitting them to the MG? Ive just got my Pinto fired up with a set on (pics on here if you do a search).
jack trolley
posted on 6/9/07 at 03:43 PM Reply With Quote
Goto BuyKawasaki.com ,
click "Owner Info",
then "Parts Diagrams"
Warning: it's a tediously slow & complicated site.
r1_pete
posted on 6/9/07 at 04:01 PM Reply With Quote
Thanks all,
Yes they're going on the Zetec in the MGB, they're currently at Boggs for the manifold.
Rgds.
Pete.
