| posted on 6/9/07 at 11:02 AM |
hydraulic clutch for 4 speed Ford gearbox
Is fitting a hydralic clutch to the 4 speed Ford box fairly easy?
Is there a slave that can bolt to the gearbox and pull the clutch lever?
And what would the master be from?
Anyone done this?
panichat
| posted on 6/9/07 at 09:45 PM |
hydraulic box
Burton produce some rather neat hydraulic slave cylinders that sit inside the bellhousing, but I'm not sure which boxes they can be used on. A
better alternative might be to get a hydraulic box off ebay (Mk 2 Cortina 1600e).
Dave
x_flow57
| posted on 7/9/07 at 09:48 AM |
I have a hydraulic clutch bellhousing from a 1600E (with fork & pushrod) if it is any use to you, it does put the starter on the o/s though.
Nick
