ghuncha
| posted on 6/9/07 at 03:59 PM |
rusty flywheel
well my flywheel was out in the open for almost 2 months.. now its rusty, pics show the details, how can i get rid of the rust, and some one told me
hat i might have to get it resurfaced.... so will the machine shop do it and is the resurfacing needed??
ghuncha
| posted on 6/9/07 at 04:00 PM |
btw the engien is toyota 4age silvertop
SeaBass
| posted on 6/9/07 at 04:02 PM |
Pah a tiny bit of surface rust!
Get the wire brush on the angle grinder... Remember to use new flywheel bolts too!
designer
| posted on 6/9/07 at 04:14 PM |
Wire brush then run over with fine emery.
graememk
| posted on 6/9/07 at 04:31 PM |
Electrolysis. See the light!
Catpuss
| posted on 6/9/07 at 04:47 PM |
Loads of non brewed condiment (cheap vinegar) will take the rust off overnight and make your garage stink like a chip shop
donut
| posted on 6/9/07 at 05:26 PM |
Hoorah!
ghuncha
| posted on 6/9/07 at 06:01 PM |
waht about Sodium hydroxide (NaOH), bu i think once the rust is removed, it come sback very quickly on the shiny surface.. so paitn it immidiately??
designer
| posted on 6/9/07 at 06:43 PM |
Vinegar every time, But don't paint it.
Macbeast
| posted on 6/9/07 at 09:31 PM |
Grease it.
No DON'T
The only bit you have to worry about is where the clutch plate bears - a bit of emery will do that. If you didn't clean that area your first few
starts might be a bit rough.
matt_claydon
| posted on 6/9/07 at 11:13 PM |
As the corrosion is uniform, I'd suggest you just let it clean itself. You could use a wire brush to remove the worst though if you like.
| posted on 7/9/07 at 09:18 AM |
wire brush or wet'n'dry on a flat block
just think of all the wieght you will save!
Mark Allanson
| posted on 8/9/07 at 07:50 AM |
Electroysis and a squirt of WD40, wipe of the driven face and the clutch will polish it up in no time.
