Pdlewis
| posted on 10/9/07 at 02:24 PM |
Cam Timming Leicester
As titled does anyone know a mobile service or garage in the leicester nuneaton area which can do cam timming or should any garage be able to do it?
Im not convinced mine is correct as i didnt measure it all propley and would quite like to get it sorted before getting my bike carbs tunned
Paul
| posted on 10/9/07 at 02:33 PM |
my suggestion would be to measure it properly.
ideally you would use a dial guage but would get away with using some as crude as a chopstick with a bit of imagination to find TDC, which is the
hard bit.
Pdlewis
| posted on 10/9/07 at 02:35 PM |
I did have a go a couple of times but ended up with a non starter would feel more better 2 get it done after unsucessful attemps as dont know what
damage it is doing now
zzr1100rick2
| posted on 10/9/07 at 03:36 PM |
What ever damage it has done has already been done get a degree disc and check cam details for correct timing
mark chandler
| posted on 10/9/07 at 05:36 PM |
2.0 ltr pinto can survive a broken cam belt with no ill effects, the pistons cannot hit the valves.
If the dots line up thats it really unless you have a vernier wheel.
Get it wrong by a tooth and the car will be extremely flat.
Regards Mark
