oadamo
| posted on 10/9/07 at 05:13 PM |
race fuel
have you used race fuel. what diffrence did it make.was your car turbo or n/a where did you get it from and how much.
adam
Russ-Turner
| posted on 10/9/07 at 05:50 PM |
Our 'Race Fuel' is Shell V-power
24vseven
not sure of its benifits totaly someone will probably set you right on that
of more help i think deamon tweeks sell it tho
delboy
| posted on 10/9/07 at 05:52 PM |
Rather than use race fuel which is very expensive, you would be better using an octane booster. Try using a quality fuel like shell optimax ( its
called soemthing different now, but you'll know it as it's more expensive than unleaded) and add a booster like silolene pro boost or
aldons equilalent. I've used it in race engines where there is a definate improvement, however, it depends on the machine work done on your
engin e.g decked block and skimmed head etc to increase compression. Using with a standard engine won't make a noticeable difference.
ChrisGamlin
| posted on 10/9/07 at 06:41 PM |
Unless your engine is specifically mapped to use it, there's no performance advantage to using high octane fuel (even bog standard Super
Unleaded / Optimax etc).
speedyxjs
| posted on 10/9/07 at 07:06 PM |
dont BP do 102 octane fuel?
omega 24 v6
| posted on 10/9/07 at 08:26 PM |
silolene pro boost
OH Yes I remember that smell well. Very potent stuff.
carpmart
| posted on 11/9/07 at 10:01 AM |
Agreed unless you are running a turbo when higher octane will help with detonation issues. Otherwise, save your money and fill with standard
unleaded!
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
snapper
| posted on 11/9/07 at 05:36 PM |
You only release the potential of higher octane fuel with a higher compression ratio.
If you have modded your engine and get detonation then go up a couple of RON values.
David Visards book explains the relationship of compression and fuel octain values
I eat to survive
I drink to forget
