auzziejim
| posted on 12/9/07 at 08:43 PM |
pinto head gasket
hi all need some help again. after the weekend running the mk and decinding that the piston ring probs were too much to ignore i have stripped it down
and now am waiting for delivery of my 2.1 short motor from JEM engines. im now buying the rest of the bits for the build up but what head gasket do i
need? obviously the 2.0 is a 91mm bore but where do i get a 93mm bore hg? burtons have a 94.5mm gasket but its about £150
so what do i do?
snapper
| posted on 12/9/07 at 08:51 PM |
I did see some cheap 93.3mm gaskets on fleabay but not sure if they will be OK.
The standard 2.0l pinto gasket is 92.8mm standard but if you have 93mm bores the gasket will squash into the bore and you either get contact or the
fire ring burns.
Burtons do a 94.5 Competition Ajusa part no. FT774G at 45 quid + VAT
I eat to survive
I drink to forget
DaveFJ
| posted on 13/9/07 at 08:21 AM |
When i had my block bored out to 2.1 by Scholar they advised me that they always use standard size gaskets!
So that is what i have used... guess i will find out if it is OK when the car is funally up and running!
Dave
| posted on 13/9/07 at 08:36 AM |
Why pour money into a Pinto ?
mookaloid
| posted on 13/9/07 at 08:38 AM |
Some people take a kind of perverse delight in making old and unfashionable things go fast - me included
Mark
DaveFJ
| posted on 13/9/07 at 09:01 AM |
My reasoning was simple.. start off with a Pinto, get it up and running, then swap for a Cosworth. that way all the mounts etc are already in place
and the conversion is simplified.
However 4 years on the car is still not on the road and i realise that my pinto is going to be enough of a handfull for a while so the Cossie
conversion plans have been shelved..... for now!
[Edited on 13/9/07 by DaveFJ]
Dave
mcerd1
| posted on 13/9/07 at 10:00 AM |
Rally design list the same part number for a few £ less - worth asking
DaveFJ - I haven't got as far as head gaskets yet on my 2.1 pinto - but I also have future cossie plans - infact its already a GM 1/2 cossie
hybrid
[Edited on 13/9/07 by mcerd1]
