paulbeyer
| posted on 12/9/07 at 10:01 PM |
Tintop has lost power
A mate at work has a Vectra 2.0 DTi that has lost power and can barely make it to 60mph top speed. When you try and accelerate it just slowly picks up
speed getting to 60mph after a couple of minutes. My first thought was the turbo had died but I can feel pressure throught the intercooler hose when
the engine is revved. I can also see the waste gate actuator arm moving at the same time. We have also had the EGR valve out and confirmed that it
also works and have checked all hoses and vacuum pipes for the turbo and EGR. I dont know what else to check now as I am not very familiar with
Vectras, is there anyone out there with any ideas as to what has gone wrong?
Paul
7 out of 10 people suffer with hemorrhoids. Does that mean the other 3 enjoy them?
stevec
| posted on 12/9/07 at 10:07 PM |
Possibly the MAF sensor, I have the same car.
Mine went dodgy.If it is the problem try LMF Vauxhall for the part, much cheaper than the dealer when I got mine.
Mark Allanson
| posted on 12/9/07 at 10:08 PM |
Sounds like it has gone into limp mode, usual cause is an oiled up crank sensor, means a trip to the main dealer for a diagnostic and fault code reset
and pay what ever figure they pluck from the air. (sorry)
stevec
| posted on 12/9/07 at 10:15 PM |
Do you think the MIL would be on if had gone into LOS?
Steve.
Mark Allanson
| posted on 12/9/07 at 10:17 PM |
only if the ULW wasn't connected to the KJG
stevec
| posted on 12/9/07 at 10:19 PM |
MIL = malfunction indicator lamp
LOS = limited operation strategy;
[Edited on 12/9/07 by stevec]
froggy
| posted on 12/9/07 at 11:18 PM |
boost control solenoid on the ns inner wing behind the headlight,there are two that look identical its the front one that fails and it doesnt put the
mil light on when it goes wrong but a scanner with live data will show it up
caber
| posted on 13/9/07 at 09:11 AM |
I'm surprised Hellfire hasn't ben along suggesting you put a bike engine in
Caber
| posted on 13/9/07 at 11:36 AM |
If it were a Rover I would go straight for a faulty MAF sensor
However worth getting the fault codes read and cleared before doing anything -- Opel/Vauxhall Diesels are only EOBD post 2003
Cheap MAF & crank sensor link
http://www.ignitionleads.co.uk/Products.aspx?Man=VAUXHALL%20OPEL&Mod=VECTRA%20C%20YEAR%202002%20%3E&Ser=VECTRA%20C%202.0%20DTI%2016V%20Hatchba
ck&Year=08/02%20%3E&BHP=74&HP=101&CC=1995&Cylinders=04&Valves=16&VID=16745&e1=Y20DTH&e2=Y%2020%20DTH
paulbeyer
| posted on 13/9/07 at 12:50 PM |
Thanks for all the replies. For some reason it sorted itself out today - back to normal power levels (for a diesel). Only thing my mate did yesterday
was to drive it with the EGR solenoid vacuum pipe disconnected for a while. At one point he dropped it down a cog and floored it, there was a large
puff of black smoke out the back and he thought he had buggered it completely. Last night he reconnected the EGR jobbie and it seems fine now.
Very strange. Any way he is off to Cornwall this weekend. If he makes it to work on Tuesday I guess the problem is sorted.
