RazMan
| posted on 13/9/07 at 09:50 AM |
Oil Cooler plumbing
My Duratec V6 has an Oil / water heat exchanger which is mounted under the oil filter. When I sorted out the cooling sytem I left this oil cooler out
of the loop but I now think it will be worthwhile connecting it to keep oil temps down a bit. The trouble is I can't remember how it was
originally plumbed in
It has 15mm hoses so it can't simply go in-line between rad and engine (32mm) or it would restrict the flow.
So how can I connect it? Do I split the rad return into two 15mm pipes to share the flow or have I missed something obvious?(not unusual)
[Edited on 13-9-07 by RazMan]
Raz
| posted on 13/9/07 at 11:55 AM |
I'd personally keep the majority of the flow going through the radiator and use a 32-15-32 T-piece to take some flow off for the oil / water
transfer thingy... At least that's how it's done on the ST engine oil / water cooler...
bimbleuk
| posted on 13/9/07 at 12:07 PM |
Either as above or maybe T into the heater matrix pipes? That's what I'm doing on the similar Ford water/oil cooler on my Toyota engine. I
don't have a heater matrix so all the flow goes through the oil cooler and back to the head. No cooling problems encountered so far.
RazMan
| posted on 13/9/07 at 01:45 PM |
Something like this? Surely the cooler wouldn't get much flow would it?
Raz
RazMan
| posted on 13/9/07 at 01:50 PM |
My heater matrix is controlled by a solenoid valve which means that when the heater is turned off there wouldn't be any flow through the cooler
if it was connected in series with the matrix.
Raz
MkIndy7
| posted on 13/9/07 at 02:26 PM |
Also the heater matrix is kept at the higher engine operating temperature usually.
Would the bottom hose be the best place for it?.
This is surely the coldest water in the system and thus has the greatest cooling capacity (Presumably the best place to give you maximum cooling
capacity, it shouldn't "over cool it" if it has a oil thermostat as part of the oil cooler system)
As for the diagram it should flow some water through it, Do you not have the haynes for the original car or find it online somewhere.
