takumi
| posted on 14/9/07 at 09:34 AM |
some exhaust progress
finally got the two 45deg I ordered from OJZ I needed to finish the primary manifold to the merge collector.
a few more tweaks needed to get the line-up improved.. but very pleased for 30mins fiddling..
worX
| posted on 14/9/07 at 09:36 AM |
looks really good!
takumi
| posted on 14/9/07 at 09:42 AM |
what I might do is, now that the tubes are roughly in the right area, I might take the collector off, and using smaller straight sections to joint
the primary tubes where they are atm to the collector in a clean staight line.. means a bit of welding, but I love it. fingers crossed it comes
out ok.
So far what you see has cost about £120
[Edited on 14-9-07 by takumi]
RobinHood 2B 2.0i pinto, Keihin 38mm Carbs, lightened flywheel, O'Mori remote filter kit, 10 row oil cooler. Modified head, 10.2cr, special
valves FR22 cam, 4- 1 header.
| posted on 14/9/07 at 09:57 AM |
looks good.
's hard to tell from the photo but how much clearance you have between the primaries and the chassis rails? The engine is going to move a bit
so allow about 20-30 mm.
scoop
| posted on 14/9/07 at 10:01 AM |
That looks bloody lovely mate
takumi
| posted on 14/9/07 at 10:30 AM |
clearance is just over 1" the engine mounts are quite firm, so its not going to jiggle around too much, unfortunately I'm going to wrap
them all up to get those gasses flowing... so it will be all hidden away..
I've got to 'glue' a catalytic converter on the end of the collector, that wrap will go all the way to end of the cat..
-emissions paranoid..
takumi
| posted on 14/9/07 at 06:59 PM |
Finally some photos os the finished article.. just some spring tabs to weld on, so the whole lot is sprung loaded together..
takumi
| posted on 14/9/07 at 07:09 PM |
you can see the straight sections of tube I've welded on to make the parallel ends for the slip-on collector.. worked a treat.
Next I've got to find some tabs I can use for the spring loading..
Has anyone used spring loaded exhausts with heat wrap..? I'm not sure If I should leave a gap in the heat wrap where the spring is, or cover
the springs under the heat wrap, but then I'm thinking the springs will get knackered with the heat possibly.?
