Author: Subject: 2 engines
oadamo
posted on 15/9/07 at 01:49 PM Reply With Quote
2 engines
how would be best to run two engines. would you put one on each back wheel. or would you run them on a chain diff.what do you think would be best.
adam
ChrisGamlin
posted on 15/9/07 at 01:51 PM Reply With Quote
There was a thread about twin engines a couple of weeks ago which covered this question........
Edited to add: here
[Edited on 15/9/07 by ChrisGamlin]
oadamo
posted on 15/9/07 at 02:02 PM Reply With Quote
iam just after a bit of info hows best to di it. as there is space between the engines i cant fit it onto one dif. i would have to run a shaft out of each side of the diff then space the two spockets then put the driveshafts on the ends. but this doesnt seem a cheap way of doing it.
adam
ChrisGamlin
posted on 15/9/07 at 03:08 PM Reply With Quote
Originally posted by oadamo
...but this doesnt seem a cheap way of doing it.
adam
And therein lies the rub, there is no cheap way of doing it, at least not reliably for general road / trackday use.
blakep82
posted on 15/9/07 at 03:17 PM Reply With Quote
one engine on the front wheels, on engine on the back wheels.
I wouldn't put one on each back wheel, incase one engine is a bit more powerful than the other, could maybe end up pushing the car to one side?
http://www.cartorque.co.za/0118.htm
well, until it caught fire anyway...
http://www.bofunk.com/video/2489/twin_engine_bomb.html
[Edited on 15/9/07 by blakep82]
________________________
ChrisGamlin
posted on 15/9/07 at 03:44 PM Reply With Quote
If you do that its great for going in straight lines, but (comparatively speaking at least) it will be hopeless in the corners unless you spend 5 figure sums on trick ECUs to manage the power balance when you're cornering, as Z Cars proved with their Z100WR
froggy
posted on 15/9/07 at 04:43 PM Reply With Quote
i seriously thought about pulling my tl out and putting a pairof tl motors in grasstrack style but opted for nitrous instead.gained the same bhp/tonne that i would have got with the extra engine but without the grief and all the extra weight
posted on 15/9/07 at 07:17 PM Reply With Quote
NS Dev on this forum has been building a twin BEC grass track car I believe - might be able to give you some pointers
ChrisGamlin
posted on 15/9/07 at 08:48 PM Reply With Quote
NS Dev has made some comments in the thread I linked to at the top, and he too suggests it will be bloomin expensive to make road reliable.
